Mccormick Deering La
4 replies to this topic
#1 Dieselcowboy OFFLINE
Dieselcowboy
  • 72 Thanks
  • 109 posts
Posted April 22, 2013 - 08:38 PM
I have just traded for my first engine. An LA. I am having trouble with it not starting very easy. Like I have blisters after I am done. It wants to go but backfires and starts to roll backwards. I thought maybe the timing might be off so I re timed it. No luck. I don't hear an impulse click like my "A" JD makes. Never the less if I get gas to it , the fire is there. Anyone ever had a similar problem?  After it finally starts it really pops hard when it runs. Is this normal? I thought it should be a little smoother.  Like I said this is my first one and I am clueless here.
#2 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 22, 2013 - 08:44 PM
Are all plug wires going to proper cylinders? I have done this before and had two cylinders mixed up and it caused backfiring.
#3 Sparky OFFLINE
Sparky
  • 1,296 Thanks
  • 1,892 posts
Posted April 22, 2013 - 09:06 PM
With old engines nothing can be taken for granted . A valve not operating properly , a bad manifold or an engine casting that cracked or became porous can cause similar problems . Checking the manifolds would be a good start.
#4 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 22, 2013 - 09:14 PM
Thinking...
Check compression and look for a consistant number through out .
#5 DougT ONLINE
DougT
    Dog Approved
  • 6,849 Thanks
  • 4,952 posts
Posted April 23, 2013 - 06:50 AM
The LA is single cylinder so it would be hard to cross the wires. I can't remember if the mag on those had an impulse or not. It almost seems like they do. Maybe you should pull the mag and check. How are you checking timing? The spark happens when the points open. You can check that in relation to the piston.
  • superaben said thank you
