What Can I Make From This?
33 replies to this topic
#1 MH81 OFFLINE
Posted April 21, 2013 - 11:46 PM
This pile of scrap has a purpose. Any guesses?
I started working on my Sears three point to sleeve hitch adapter today. Got a lot done only to find out that the plans I printed out over a year ago have an error... It's OK tho I will fix it, have a plan in place.
My goal was to build one of these
I didnt really care what it looked like. Old steel and no paint was fine, just wanted to be able to use a couple of implements on my sears.
In the plans, it tells you how to make all the parts... Dimensions, degree angles, etc... Except I did not see the fact that the person made their own arms... 15 inch, instead of the usual 18... Crap.
So, I am either going to make an extension top link or add 3-4 inches on to the top of the adapter.
It does look like it'll work, just need to tweak a little.
  • hamman, KennyP, boyscout862 and 7 others have said thanks
  • 14,814 Thanks
  • 15,502 posts
Posted April 21, 2013 - 11:52 PM
Great looking Sears 3pt to Brinly adapter you built Alan. Should do the job just fine for you. :thumbs:
  • MH81, larryd and MyBolens1053 have said thanks
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 21, 2013 - 11:56 PM
Looks great Alan. I think you could weld another piece of the frame on there to extend it to the top link and no one would make fun of you, nor would it look bad.
#4 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 21, 2013 - 11:57 PM
Although it is a shame you already welded it all solid.
  • MH81, Huskyfan, larryd and 1 other said thanks
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted April 21, 2013 - 11:58 PM
Or did you get it solid.... Maybe the welds will break this weekend lol.
  • MH81, Huskyfan and larryd have said thanks
#6 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 22, 2013 - 12:00 AM
That'll do the trick. Looks plenty strong. Like Cassey said, add to the adaptor.
  • MH81, wvbuzzmaster, larryd and 1 other said thanks
#7 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 22, 2013 - 12:14 AM
That looks good Allen. You sure have been busy today :D
#8 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted April 22, 2013 - 03:56 AM
Nice welds Alan, and cuts with the torch!! Great job!
 Now, I bet  that plow is heavy to lift ?  I would have tried to get it as close to the tractor as possible with out interference . this way it would have less affect on the tractor, may act as a rudder because it is so far out the back .. It may also be hard to gage your depth too?
#9 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted April 22, 2013 - 04:52 AM
That's cool, Alan. I'm sure you will figure out something for the top link. I just hope it isn't too far back and hard to lift. If I remember correctly, the Sears 3-point plow is shorter than the sleeve hitch one.
#10 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 22, 2013 - 05:01 AM
Very nice alan. Looks very strong and should never break. Nice looking welds.
#11 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted April 22, 2013 - 05:05 AM
Looks like a nice weekend project.. It looks like it is heavy enough to last a long time.
#12 Alc OFFLINE
  • 6,905 Thanks
  • 7,468 posts
Posted April 22, 2013 - 05:41 AM
Looks good :thumbs:   Would it be much trouble to make a longer top link ?   I need to make a longer top link for my PK for when I use the disc for hilling
#13 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted April 22, 2013 - 06:02 AM
Suggestion on the top link. If you can find one at TSC that has a longer center section, could your original ends be screwed into it and give you a longer top link? Just a thought. Or buy one with a short center and lengthen that. At least I hope the threads are the same!
#14 MH81 OFFLINE
Posted April 22, 2013 - 06:14 AM
My plan is to make a temporary one this week and then see how it works, then decide how to extend.
This is a pic for sears pt number 917.253182 sleeve hitch adapter.
Note the arms, they did make shorter ones for this... I don't want to swap arms every time I want to use the box blade, so I get to do a little trial and error.
  • KennyP, Huskyfan, larryd and 1 other said thanks
#15 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted April 22, 2013 - 06:38 AM
Good luck with it, Alan! Have you got a helper spring on the lift? You might need something if it's further back.
  • larryd and MyBolens1053 have said thanks
