Cotter Pins
22 replies to this topic
#1 thom OFFLINE
thom
  • 339 Thanks
  • 244 posts
Posted April 21, 2013 - 10:10 PM
This might be a silly question but...I wonder how cotter pins were spread by manufacturers when machines like ours were made? Were both sides bent around the axle or whatever shaft they were used on? Was only one side bent around? If so, which one, the long side or the short side? How long should the right pin be? Twice the diameter of the shaft, less or more? Did it vary from one manufacturer to another, or is there a "RIGHT" way? Maybe someone on here is a mechanical engineer and can say for sure. All my junk has been worked on so much none of the pins are factory and a lot of them have been replaced with nails or pieces of wire.Like I said , silly question , maybe, but inquiring minds gotta know. Thanks.
  • boyscout862, LilysDad, larryd and 1 other said thanks
#2 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted April 21, 2013 - 10:20 PM
I'm gonna say it depends on the manufacturer. But it also would depend on the person assemblying it. To many variables I think to get a straight answer.
  • boyscout862 and larryd have said thanks
#3 Ryan313 ONLINE
  • 3,364 Thanks
  • 5,230 posts
Posted April 21, 2013 - 10:27 PM
Depends, some of my tractors even have left hand cotter pins... That's a whole different can of worms.
#4 PaPasTractor OFFLINE
PaPasTractor
  • 197 Thanks
  • 158 posts
Posted April 21, 2013 - 10:44 PM
Hi Thom,  No such thing as a silly question....We don't learn if we don't ask.
:iagree: with Nate on the manufacturer.
I personally bend them both ways unless I will be removing ( eg.hitch pin) and then just one side part way.
Sometimes you would have to bend both ways, like to get the dust cover cap on a trailer bearing.
As far as size, that would be per app ( length & dia.)       Dave
#5 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted April 22, 2013 - 12:07 AM
Bending both sides will keep a pin from turning and rubbing in close spaces like inside a dust cap.  If it's a low vibration and tension situation and the pin needs to be removed often, only open one side of the pin about 45º for easier multiple uses.  On a rod application the bent pin arms should reach at least 3/4 around the pin.  This is mid 50's auto shop knowledge and may be obsolete by now.  Most everything I thought I knew, today is obsolete!:D
  • boyscout862, superaben and larryd have said thanks
#6 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,750 Thanks
  • 4,244 posts
Posted April 22, 2013 - 12:22 AM
silly question - never heard before! but many silly answers!
  • JDBrian, boyscout862 and larryd have said thanks
#7 jdslednut ONLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted April 22, 2013 - 12:23 AM
I was taught for trailer bearings to bend the longer end toward you and tap it flat against the end of the spindle.  Then, snip off the shorter one.  Guy I worked for in college in Mlps said that's how he could tell I must have grew up on a farm.  Farm boys got to start out at $1 per hour more than the city slickers.
  • superaben, Arti and larryd have said thanks
#8 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,984 Thanks
  • 9,629 posts
Posted April 22, 2013 - 06:46 AM
I've even wondered if the first cotter pins were hand manufactured by the mechanics.
  • larryd said thank you
#9 boyscout862 ONLINE
  • 12,545 Thanks
  • 9,043 posts
Posted April 22, 2013 - 07:03 AM
Bending both sides will keep a pin from turning and rubbing in close spaces like inside a dust cap.  If it's a low vibration and tension situation and the pin needs to be removed often, only open one side of the pin about 45º for easier multiple uses.  On a rod application the bent pin arms should reach at least 3/4 around the pin.  This is mid 50's auto shop knowledge and may be obsolete by now.  Most everything I thought I knew, today is obsolete! :D
The knowledge is not obsolete. It is just not popular in our throw away society. I have a nineteen year old who is about to graduate in nuclear engineering. I show him some of the old ways to do things on machines and some of my 45 year old tool collection and what they do. HE is very bright and I explain things the old(rational) ways and compare to the current methods. He usually laughs and has trouble with understanding why standards have been reduced. I hope he and other interested young people will treasure the "obsolete" knowledge that we old guys have. If our fragile economy takes a tumble people will have to learn to maximize what they get out of their belongings. The old knowledge will be very valuable then.
Edited by boyscout862, April 22, 2013 - 07:04 AM.
  • IamSherwood, Nato77, superaben and 1 other said thanks
#10 Lmiller3358 ONLINE
Lmiller3358
  • 1,480 Thanks
  • 1,419 posts
Posted April 22, 2013 - 07:51 AM
Yeah, and then you need to have left handed pliers to do that !
#11 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted April 22, 2013 - 07:53 AM
  And then you need the left handed pliers to bend them, LOL!!
                                               Mike
#12 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 22, 2013 - 08:34 AM
I've bent to fit application or replace with slip pins if possible
larryd
#13 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 22, 2013 - 08:44 AM
 I agree with Harold as this is right. I tend to buy Cotter pins long and clip them as needed.
I'm detecting a bias against Left Handed and am mildy offended. :D  Remeber Left Handed People are in their Right Mind.
BTW: How many remeber the old Mopars, With Righthanded thread Lug Nuts on one side and left handed on the other, so they would not work loose due to ratation direction??
Edited by JD DANNELS, April 22, 2013 - 08:47 AM.
#14 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted April 22, 2013 - 08:53 AM
I concern with Harold, fold the longer end around and clip the shorter end.
Dick
#15 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted April 22, 2013 - 09:06 AM
I've seen people twist many lug nuts off because of that. The older semis with bud wheels are still a pain. The inner nut seems to always come off with the outer nut on the left side. IMO I think they still work loose just as easy.
