Get A Grip On This...
15 replies to this topic
#1 WHdbJD ONLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted April 21, 2013 - 09:55 PM
OK, ,,so I'm lookin on HAPCO  and I see they have the rubber grips for the
variator and manual lever. The ones on my 110 and 210 are split and ugly. How are the
old grips removed and the old ones installed?   Just cut 'em off and force the new ones on??
  • larryd said thank you
#2 Grumpy ONLINE
Grumpy
  • 721 Thanks
  • 617 posts
Posted April 21, 2013 - 10:31 PM
Cut the old one off. Use a heavy duty silicone as a lubricant, not WD-40. It should slide right on. Have block of wood and a hammer ready just in case.
#3 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted April 22, 2013 - 12:13 AM
I believe those are still available from Deere if you want to compare pricing.
#4 MH81 OFFLINE
Posted April 22, 2013 - 06:37 AM
The couple of times I've had to take those handles off/on on the Massey tractors, I've carefully used a hair dryer to heat it up. Made the job 300% easier. Just don't get it to hot and melt it
  • IamSherwood, Moosetales and larryd have said thanks
#5 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted April 22, 2013 - 07:38 AM
i use brake parts cleaner to get them on it makes the rubber really slippy and they slide right on
  • MH81 and larryd have said thanks
#6 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 22, 2013 - 08:37 AM
Hair dryer off and white lube on makes a good combination
larryd
#7 WHdbJD ONLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted April 23, 2013 - 04:38 AM
Thanks for all the replies!
#8 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,497 Thanks
  • 1,817 posts
Posted April 23, 2013 - 05:10 AM
The way I did my motorcycle grips was with hairspray. The hairspray would provide lubricant to get the grip on then dry and become sticky to keep it on.
Eric
Sent from my XT897 using Tapatalk 2
  • MH81, IamSherwood, WHdbJD and 1 other said thanks
#9 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted April 23, 2013 - 08:31 PM
I put all of my new ones on by using vasaline. Just wipe away whatever oozes out with a paper towel.
  • WHdbJD said thank you
#10 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted April 24, 2013 - 01:54 AM
My dad stands by liquid soap for the very same reason dropped82 mentioned using hairspray. Always seemed to work great for him.
  • MH81 and twostep have said thanks
#11 WHdbJD ONLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted April 24, 2013 - 03:32 PM
I got enough suggestions here, I can try a different one on each handle grip!
#12 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted April 24, 2013 - 03:50 PM
Great idea, don't forget to report back in a year! :D
#13 WHdbJD ONLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted April 24, 2013 - 05:16 PM
Sometimes it takes me that long to get even a small project done!
#14 whst400 OFFLINE
whst400
  • 25 Thanks
  • 29 posts
Posted April 29, 2013 - 11:16 PM
Cut the old ones off. Clean the surface that will be covered by the new ones. Heat the new ones up in boiling water. Lubricate the surface with liquid dish soap and slide the new ones on. They will expan slightly while warm and contract when they cool. The very thin film of soap that remains between the surface and the grip will also dry and become and adhesive.
#15 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted May 06, 2013 - 10:08 PM
you can also try lighter fluid and double sided tape
put the tape on the shaft and put light fluid in the grip and some on the tape - then slide on the grip and wait around 24 hours
that is how I was taught when I work at a Des Moines golf & Country Club in the pro shop
