Need Gas Tank For Lgt100
12 replies to this topic
#1 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 21, 2013 - 03:04 PM
I am trying to get this tractor up and running. So far I know i am missing the proper gas tank. I am not sure what it even looks like so if anyone has one, or and get me a picture of one so I know what I am looking for.
Thank you Adam
http://gardentractor...attach_id=68130
Edited by bread320i, April 21, 2013 - 03:06 PM.
#2 Rock farmer ONLINE
Rock farmer
  • 1,299 Thanks
  • 1,274 posts
Posted April 21, 2013 - 03:51 PM
Joe
Edited by Rock farmer, April 21, 2013 - 03:51 PM.
#3 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 21, 2013 - 04:22 PM
Thank you Joe. that looks like a kohler made tank.
#4 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted April 21, 2013 - 05:14 PM
Cub cadet first series wide frame gas tank will work for you.Cc 108,109,128,129,149.
  • bread320i said thank you
#5 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 22, 2013 - 06:05 AM
Thank you Josh. This info just made my searching easier
#6 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted April 22, 2013 - 08:46 AM
No problem!
#7 Old Door OFFLINE
Old Door
  • 2 Thanks
  • 13 posts
Posted June 24, 2013 - 08:57 AM
My plastic gas tank on my Lt100 leaks.Is it possible to seal it with a seal kit for vehicle tanks?I think critters got at it over winter.
#8 poncho62 ONLINE
poncho62
  • 2,127 Thanks
  • 1,794 posts
Posted June 24, 2013 - 06:17 PM
Depends how big the hole is.....A couple of mine had pinholes, I used gas tank sealer on them.
If your hole is too large, you could JB weld a patch on and then use the sealer
  • Old Door said thank you
#9 Rock farmer ONLINE
Rock farmer
  • 1,299 Thanks
  • 1,274 posts
Posted June 24, 2013 - 06:23 PM
I had a crack on my John Deere plastic tank. I just used super glue on it. The leak was near the top of the tank, but, it worked!
Joe
#10 Old Door OFFLINE
Old Door
  • 2 Thanks
  • 13 posts
Posted June 25, 2013 - 12:45 PM
Thank you guys.I will try your suggestions.It was pointed out I have a lgt100 instead of LT100.I didn't know as I just got tractor and don't know a lot about it yet.
#11 poncho62 ONLINE
poncho62
  • 2,127 Thanks
  • 1,794 posts
Posted June 28, 2013 - 05:51 AM
LGT100...Does it look like this?
#12 Old Door OFFLINE
Old Door
  • 2 Thanks
  • 13 posts
Posted June 28, 2013 - 07:55 AM
yes it does but not as clean.mine has full side panels and top opens to the front to get to gas tank and oil. thanks for pic very nice Ford.
#13 poncho62 ONLINE
poncho62
  • 2,127 Thanks
  • 1,794 posts
Posted June 29, 2013 - 06:51 PM
The ones that have the side panels are 77-83, I believe
