Temporary Carb Needle Seat
11 replies to this topic
#1 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted April 20, 2013 - 06:04 PM
Wanted to use my Troybilt tiller with 6.5hp Briggs Intek.  Wouldn't run without carb spray shots.  Took carb apart & the rubber float needle seat was swollen shut.  Removed it & it came apart.  So, wanting to do this little bit of tilling, I found a tiny std o-ring that was just a tad too large to fit right in place of the seat.  I slipped the o-ring onto a piece of wire, then with the bench grinder, let it spin-grind the outer edge of the 0-ring down to reduce it's size, and to make a flat side for it to not want to roll in the hole.  Put all back together & she runs great!  Temporary though, as the needle doesn't seal perfectly, but great while it's running....just drips a little when shut off.  But until I can get the new seat (all shops closed on weekends), I can still till!   :thumbs:
  • MH81, hamman, sacsr and 3 others have said thanks
#2 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 20, 2013 - 06:41 PM
Congrats on the great idea of a quick fix! Glad you got to do some tilling and not had to wait till Monday :thumbs:
  • olcowhand said thank you
#3 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 20, 2013 - 06:48 PM
Necessity is the mother of invention. :thumbs:
Plus, it helps, that you're smart. :thumbs:
  • olcowhand and MH81 have said thanks
#4 UncleWillie OFFLINE
  • 15,670 Thanks
  • 8,761 posts
Posted April 20, 2013 - 07:50 PM
Somehow my temporary repairs have a way of becoming permanent.
  • olcowhand, Alc, HDWildBill and 1 other said thanks
#5 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted April 20, 2013 - 08:10 PM
Actually, if I simply installed an inline fuel valve, then this could be left as-is, but without it, it will empty the tank.  Cheaper to buy a new seat....but then still not a bad idea to have a shutoff valve also.
  • HDWildBill said thank you
#6 UncleWillie OFFLINE
  • 15,670 Thanks
  • 8,761 posts
Posted April 20, 2013 - 09:10 PM
If you were closer I would give you a shut off. I several from taking apart those tractors.
#7 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted April 20, 2013 - 09:12 PM
Oh, I have a new one in my toolbox, but I need a new piece of fuel line if I want to put it on.  The OE fuel line looks like it would crumble if I cut it to install the valve.  I think I have a piece of new fuel line around here somewhere too.
#8 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted May 04, 2013 - 05:15 PM
Just ordered a new needle/seat kit.  Original Briggs kit delivered to my mailbox for just $4.85.  I can't get a true Briggs kit for that price at my local small engine parts place as they list for around $5.
#9 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 04, 2013 - 05:29 PM
Wow a neat idea!  I'll have to try and keep that in mind should I have a similar problem.  :thumbs:
#10 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted May 04, 2013 - 05:31 PM
Yep, it'll limp you through for sure.  I figured I'd better get one ordered while I was thinking about it.
#11 HDWildBill OFFLINE
  • 8,975 Thanks
Posted May 04, 2013 - 05:49 PM
10 minutes later and I would forget all about it.  Best to do it while you are thinking about it.
#12 MH81 OFFLINE
Posted May 05, 2013 - 07:14 AM
That's using your noodle OC, thanks for the work-around.
