John Deere 318 Questions
pto clutch removal wiring diagram
6 replies to this topic
#1 miniacs OFFLINE
miniacs
  • 2 posts
Posted April 20, 2013 - 04:39 PM
Where would I find a wiring diagram for a 318? I changed engines and it will not start with the key. I can jump the starter relay. The ignition switch is good but it will not energize the purple wire to the relay.
What are the steps for removing the pto clutch from an Onan P218?
#2 HDWildBill OFFLINE
  • 8,984 Thanks
Posted April 20, 2013 - 04:53 PM
Welcome to GTtalk.  Unfortunately JD lawyers sent us a letter a while back to remove any and all JD material. if it is the purple and white wire it goes through the brake and transmission neutral switches.
#3 nbent ONLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted April 20, 2013 - 07:41 PM
welcome to GTtalk I sent you a PM, personal message, containing a diagram for your tractor that should work
#4 boyscout862 OFFLINE
  • 13,550 Thanks
  • 9,427 posts
Posted April 20, 2013 - 07:55 PM
Welcome to GTT.
#5 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted April 20, 2013 - 08:13 PM
Welcome to GTTalk !  I should be able to help you with your pto question but will have to look at mine tomorrow to refresh my memory ,
#6 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted April 20, 2013 - 09:38 PM
man i hope this works and hope it helps .
Edited by Gary400, April 20, 2013 - 09:56 PM.
#7 miniacs OFFLINE
miniacs
  • 2 posts
Posted April 21, 2013 - 11:44 AM
thanks, got the PTO clutch changed, someone never siezed it last time slid right off. the wiring diagrams look good.
Also tagged with one or more of these keywords: pto clutch removal, wiring diagram
