K161 Governor
6 replies to this topic
#1 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted April 20, 2013 - 03:35 PM
OK I got the Troybilt running but the Gov is not working, it vibrated and came off, and I'm sure how to put it back together.
I am thinking this spring goes into the slot. but it seems awful strong.
  • larryd said thank you
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,346 Thanks
  • 9,800 posts
Posted April 20, 2013 - 04:15 PM
Did you check the service manual?http://www.kohlereng...als/landing.htm
#3 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted April 20, 2013 - 04:18 PM
Yes I have, but it doesn't show it, or at east I can't find it.
#4 Grumpy OFFLINE
Grumpy
  • 721 Thanks
  • 617 posts
Posted April 20, 2013 - 04:58 PM
My book show to loosen the nut so the arm is free, rotate the shaft ccw all the way, then pull the carb. all the way open with the gov. and tighten the nut
#5 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted April 20, 2013 - 05:08 PM
I understand that part, but does this spring go into the slot?
I seems awful tight and I get no gov control.
#6 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted April 20, 2013 - 07:24 PM
Well I figured it out, somebody was trying to use the arm to open the throttle, and they had to loosen the brass nut to it. The arm is used to attach the cable housing to, and the nut adjusts the max RPM. The cable is supposed to attach to the disc. Well everything vibrated loose and I had to figure out how the parts went back together. After some tinkering I think I have it now.
  • boyscout862 and Arti have said thanks
#7 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,346 Thanks
  • 9,800 posts
Posted April 20, 2013 - 08:55 PM
I spent this time trying to find a you tube photo for you, but no luck. Your right with that arm. The spring is pretty stiff when the engine isn't running. Good job!
