Shuttle Drive
4 replies to this topic
Bob IN
  • 1,477 Thanks
  • 676 posts
Posted April 20, 2013 - 03:13 PM
I just got an old 712s. I will get pictures soon.  Is the shuttle drive a good transmiton? Does it take more up keep than a regualr transmtion? Its all new to me.
#2 glgrumpy OFFLINE
  • 8,652 Thanks
  • 7,941 posts
Posted April 20, 2013 - 07:49 PM
This the kind with a rubber tire out on a small wheel that rides back and forth to change speeds?  Gilson used long time??  I try to avoid those. Not sure if same as you are asking tho.
#3 bread320i OFFLINE
  • 613 Thanks
  • 1,225 posts
Posted April 20, 2013 - 08:39 PM
Simplicity Shuttle Shift tractors are nothing to be concerned about. They were built and designed well. Most people say they are better then your standard 3 speed but do not replace your hydrostatic tractors.
#4 yardiron OFFLINE
  • 38 Thanks
  • 82 posts
Posted April 21, 2013 - 11:24 PM
Personally I've always thought the Shuttle was ok, but there's been a few posts here about having to adjust them occasionally and a few about belt slippage. I had issues with one of mine too with the belt slipping when climbing steep hills, but it never slipped under normal use or when cutting grass. Basically its just a four speed manual transmission with a planetary system for reverse, which allows you to shift forward to reverse while moving.
#5 skunkhome OFFLINE
  • 323 Thanks
  • 455 posts
Posted April 23, 2013 - 09:31 PM
I'm quite happy with my shuttle, but it took some study for me to truly understand it. I did spend some time getting the adjustment right but once adjusted it doesn't take much to keep it running top notch. I just check it every oil change and tweak as necessary.
