Wood Stove for the shop
49 replies to this topic
#31 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted October 18, 2011 - 10:19 AM
In the back ground of the last photo I see a ceiling fan setting on a bucket. Use it! Put it in the highest spot in the ceiling and have it blowing down. Preferably in the center of the room. This will make a huge difference. I converted my double barrel wood stove to burn waste oil and have never looked back. Took me several years to come up with a simple burner that burned clean but now I can throttle the stove from warm to red hot and my non insulated shop is toasty warm even when below zero. If I was good with this darn computer I would make a diagram like yours of the burner and post it. Extremely easy to make. My stove pipe is old 8" auger tubing. It goes out the back wall where it tees into the vertical pipe. The bottom of the vertical pipe sets on the ground and runs up the back of the shop to above the peek. Been there for 30 years and has worked like charm.
Good luck with your project. What program do you use for your drawings? They look good.
Would love to see how you designed the waste oil burner.
Especially the throttling part of the design.
Not to steel this thread perhaps on a new thread.
Thanks in advance.
#32 Cvans OFFLINE
  • 7,285 Thanks
  • 6,376 posts
Posted October 18, 2011 - 10:43 AM
I think Chuck has me headed in the right direction. If I get a drawing done I will start a new string.
#33 Cvans OFFLINE
  • 7,285 Thanks
  • 6,376 posts
Posted October 18, 2011 - 09:16 PM
:hijacked: Well I tried google sketch up and what I've discovered is that I can't even draw a straight line with it. So I will build another burner and take photos of it. I've used the other one for 3 years now and I have been wanting to enlarge the preheat pot anyway so I'll start another string then.
Back to Chucks wood stove.
#34 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted October 30, 2011 - 07:52 AM
I got the wood stove and chimney installed yesterday.
#35 KennyP ONLINE
  • 40,885 Thanks
  • 47,094 posts
Posted October 30, 2011 - 08:10 AM
Sketch up can be a bit of a challenge to start with. I also have this on my computer: progeCAD: progeCAD Smart 2009
More like Autocad for those of you so inclined.
#36 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted October 31, 2011 - 08:39 AM
here are some pictures.
This is my homemade double walled section for where it goes through the roof. The 6" sections runs straight through this contraction made of a 6" to 8" increaser, a section of 8" pipe, and a 8"6 reducer.
the hole I cut in a perfectly good roof. I was very stressed doing this.
Pipe coming out of the roof.
A view of the stack.
the stove
The inside pipe.
#37 mjodrey OFFLINE
Posted October 31, 2011 - 08:47 AM
Lookin' good there ,Chuck.
#38 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted October 31, 2011 - 08:50 AM
Lookin good Chuck.
That should keep you warm this winter.
#39 olcowhand OFFLINE
  • 42,896 Thanks
  • 31,939 posts
Posted October 31, 2011 - 11:30 AM
Yep, you're gonna be toasty warm in that shop Chuck! Great wood stove, and styro insulation. You'll have to open the door to cool off!
#40 Cvans OFFLINE
  • 7,285 Thanks
  • 6,376 posts
Posted October 31, 2011 - 11:37 AM
Neat and clean installation. I think your building is about a hundred years newer than mine so should be easy to heat. Sell that propane tank and buy another tractor.
#41 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted October 31, 2011 - 02:01 PM
Ahhhh Yes, there is nothing better than that nice wood heat and smell that comes from a wood stove.In Ontario here, the insurance company's think your going to blow the whole town up ,even though years ago that's how alot of us use to heat our homes and our parent's, and grandparents,and so on.....You know back in those good old days ! Oh by the way , that looks great Chuck.
#42 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted October 31, 2011 - 07:04 PM
i need to get mine back up before it gets cold . that looks good Chuck
#43 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted November 01, 2011 - 07:47 AM
If I had another heat source for the house that propane tank would be a lot smaller.
#44 KennyP ONLINE
  • 40,885 Thanks
  • 47,094 posts
Posted November 01, 2011 - 07:54 AM
That will take the chill off things. Looks like a good installation. Good luck with it.
#45 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted November 06, 2011 - 09:15 AM
Great ideas and I 'm going to double-wall mine in a similar manner next week. I'd like to offer a suggestion too if that's O.K.? Mine was similar before I relocated the stove (similar roof). Up hill from the pipe, where it joins the roof rib would pack full of standing water and also pine needles . Finally, I installed a piece of flashing to "raise" the flat area between the ribs so that run-off would go around the pipe. This next hole will be dead-centered on the rib.
