Ford Lgt100 And Jacobsen Gt16 Compatability
11 replies to this topic
#1 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 19, 2013 - 03:24 PM
I got this LGT 100 which has a blown motor. I also have a Jacobsen GT16 which is a parts machine with a good 16hp motor
Just curious before I pull out the tools and get dirty, will the 16hp Kohler from the Jacobsen GT16 fit on the oil pan of the Fords LGT 100 10hp Kohler?
I will also need a fuel tank as neither tractor has one.
#2 poncho62 ONLINE
poncho62
  • 1,996 Thanks
  • 1,744 posts
Posted April 19, 2013 - 05:09 PM
I am not sure if the 16 hp block will fit the 10hp pan......Why not just use the 100 for parts to fix up the GT16?
#3 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 19, 2013 - 05:37 PM
The Jacobsen is missing parts that are not shared with the Ford.
I also prefer the Ford over the Jacobsen.
#4 EricFromPa OFFLINE
EricFromPa
  • 4,006 Thanks
  • 3,266 posts
Posted April 19, 2013 - 05:41 PM
Yes the pan will bolt up if they are both Narrow base blocks.Make sure that you measure the oil dipper on the bottom of the connecting rod on both engines.They should be the same length but I would measure both just to be sure.You don't want to accidentally put a long dipper into a shallow well oil sump.
All of the differences between a 10 and 16hp block are from the jug up and the crank.
I used a bearing plate,flywheel with ring gear and ssi module off of a blown 16hp kohler magnum on my neighbors cub cadet 109.Converted it from starter genny to ring gear start and solid state ignition with stator charging system.
Edited by EricFromPa, April 19, 2013 - 05:50 PM.
  • Arti said thank you
#5 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted April 20, 2013 - 04:20 AM
 Bolt right on if as stated earlier, they are both narrow blocks. Is the Jake an old style like the Ford (72-76 model) if so it will bolt right on.
 The standard shift frames are different from the hydro frames but all the sheet metal is basically the same . Only where a deck lift handle goes is the differences.
#6 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted April 20, 2013 - 06:09 AM
Yes I believe the Jacobsen is from the same time frame.
#7 101 senior OFFLINE
101 senior
  • 245 Thanks
  • 374 posts
Posted April 23, 2013 - 05:00 PM
 Pauls small engine in Seneca Falls, NY. He has parts for the LGT series, He has a like new Ford stored in  where he keeps the really good tractors. And he told me he has a tiller for the Fords.
#8 poncho62 ONLINE
poncho62
  • 1,996 Thanks
  • 1,744 posts
Posted April 23, 2013 - 05:42 PM
So....he has a bunch of Fords stored there???
#9 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted April 24, 2013 - 03:22 AM
http://gardentractor...attach_id=48332
http://gardentractor...attach_id=48333
This will work as well.
And this is installed
http://gardentractor...attach_id=49063
http://gardentractor...attach_id=46038
This last pic shows the tiller installed on the 3 point hitch upper rocker assembly
Edited by skyrydr2, April 24, 2013 - 03:29 AM.
  • Rock farmer said thank you
#10 101 senior OFFLINE
101 senior
  • 245 Thanks
  • 374 posts
Posted April 24, 2013 - 04:31 PM
He has a ford like new stored there. He does have some parts and he said he had a ford tiller. You should check w/ him before making the trip. he has a web page w/ phone #.
#11 Rock farmer OFFLINE
Rock farmer
  • 1,245 Thanks
  • 1,248 posts
Posted April 24, 2013 - 06:34 PM
Keith,
What's that third picture? Is that your tractor?
I see a hydro cylinder for the rear lift, extra Hydro lines and is that a belt driven pto? Just a standard jake 90 degree gearbox and a long belt to the front mule drive? Was there a thread on this?
Thanks!
Joe
#12 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted April 24, 2013 - 07:50 PM
Keith,
Thanks!
Joe
There really isn't any on those as they required some serious monkeying to get correct.
The rear pto is completely revamped and has a jackshaft and sub frame that are reqired to get the speed correct and belts to work.
The tractor that is mounted on has a diesel with aux. Hydraulics.
