Cub Cadet 582 Pto Switch
3 replies to this topic
#1 cubcadetguys OFFLINE
cubcadetguys
  • 7 Thanks
  • 19 posts
Posted April 18, 2013 - 09:04 PM
I have a Cub Cadet 582. The PTO switch will only run the deck if I hold it up. If I let go and it goes in the middle postion to run the deck it shuts off. I can mow the whole yard if I hold it up. I replace the PTO switch and it does the same things. Wonder if any body had this problem. Thanks
#2 Jlaws OFFLINE
Jlaws
  • 556 Thanks
  • 368 posts
Posted April 18, 2013 - 09:33 PM
I'm thinking safety switch , I'd check your seat switch first .
  • cubcadetguys said thank you
#3 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted April 19, 2013 - 07:25 AM
:ditto:   I think that would likely be the issue. It's possible the switch is messed up and it needs the extra bit of weight from when you lift the deck to run it.
That's what I am thinking anyway.
#4 cubcadetguys OFFLINE
cubcadetguys
  • 7 Thanks
  • 19 posts
Posted April 22, 2013 - 10:38 PM
Thanks guys it was the safety switch.
