Carb Adjustments
21 replies to this topic
#16 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted April 22, 2013 - 06:19 PM
Have you checked for an air leak?  If the carb was professionally cleaned and you have a new air filter and you can't seem to get the setting right I think I would be checking for an air leak around the manifold.
I got back to it today.  I started it up and ran it for a few minutes then I sptayed 2+2 gum cleaner where the carb bolts on.  It smoothed right out.  (This is how I used to check vaccum lines on cars.)
I pulled the carb and replaced the gaskets.  Engine - gasket - isolator plate - gasket - carb.  Still leaked so I walked away a little frustrated.  I went back out atter everything cooled down and pulled the carb again.  This time I am noticing that the carb studs have metal shavings in the threads.  I am thinking that maybe the nuts are bottoming out where the threads end and can't tighten enough to stop the air leak.  Maybe if I add a washer or 2.  I am not sure how well the lock washers will work that are part of the mounting nuts.
#17 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted April 22, 2013 - 09:40 PM
throw some new lock washers on there and see what happens.
  • robert_p43 said thank you
#18 KennyP ONLINE
  • 38,181 Thanks
  • 45,841 posts
Posted April 23, 2013 - 07:12 AM
Have you checked the carb mounting surface for warpage? That needs to be flat!
  • MH81, robert_p43 and superaben have said thanks
#19 MH81 OFFLINE
Posted April 23, 2013 - 07:18 AM
Xcellent point, sometimes the ears will bend and cause an air gap. To not straighten, I have broke them. If I have a bent one now, I resurface with a sheet of fine sandpaper on a flat surface.
The other thing you could try is double up the gaskets. That might get you where you need to be.
#20 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 23, 2013 - 08:22 AM
Kenny's the man this morning.  I'd check what he advised.
Is the throttle shaft worn?  Maybe it could get a sniff of 2+2 through the shaft?
Ben W.
#21 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted April 23, 2013 - 07:34 PM
I removed the carb today and set a straight edge across the ears.  Whoa!  Must have been a 1/32 - 1/16 inch gap where I could see daylight.  I used a flat file across the ears for a half hour or so.  Cleaned everything up and pur her back on.  Same thing.  I went to find my sand paper and spotted the metal box where I keep a supply and I would have to move a bunch of stuff to get to it that was piled in front of it over the winter.
I went out later to take some strawberries over to my grandbabies.  She is about 4 1/2 and was happy to get the berries and see her Grampa.  On the way home, I stopped to see Frank and got a piece of sandpaper from him.  I went through the whole routine again and set the paper on a pirce of glass and took about 80 strokes till everything looked shiney.  Reassemble and it sure does sound better.
The problem is still there but not as bad.  I didn't spray the throttle shaft but I am sure air gets in there too.  I did set my finger on it and it wiggles.  I think I'll live with it for awhile and fiddle with other things that need done to it, like those belleville washers, another oil change, transmission oil change, etc.
  • MH81 and superaben have said thanks
#22 TAHOE OFFLINE
TAHOE
  • 7,946 Thanks
  • 5,666 posts
Posted April 24, 2013 - 08:12 AM
Sounds like you found the major problem, kudos.
My LMH carb on my 16 sucks a little air through throttle shaft, I get a little miss/popping occasionally. Not enough to aggravate me yet. I'll ship it to Mark and let him replace bushing for me when the time comes.
