Case Down..
3 replies to this topic
#1 Justin2655 OFFLINE
Justin2655
  • 204 Thanks
  • 148 posts
Posted April 18, 2013 - 04:07 PM
The other day (when it was actually nice out) I took my 220 out and was doing some yard work, picking up the yard and such, when to go hook up to the roller and went to take off and it started spitting oil out in between the head and block, took it apart and sure enough the head gasket was blown, is that my only problem? Just the oil spitting out before the head gasket blew kinda made me wonder if I had other problems or it was just the head gasket getting ready to let go? It smoked when it ran but figured it was just rings, would it still be rings as well or would it have been my head gasket that was causing a lot of it? Thanks justin
  • Rock farmer and JRJ have said thanks
#2 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted April 18, 2013 - 06:06 PM
serial no of tractor. Could check crankcase breather.
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted April 18, 2013 - 07:22 PM
gopher is right, breather would be a good thing to check.  Unless it is an unusual engine (and I'm no Case guy, so someone whack me if I'm wrong) the head gasket will not cause oil to get into the cylinder that wasn't already there.  Rings is your other option.
You wouldn't have accidentally overfilled the oil, would you?
Ben W.
#4 Justin2655 OFFLINE
Justin2655
  • 204 Thanks
  • 148 posts
Posted April 18, 2013 - 08:23 PM
It's a 10 horse kohler motor, always started and ran good till that happend
