need to know correct voltage regulator
8 replies to this topic
#1 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted October 18, 2010 - 10:49 AM
On that B-10 that I just found, of course the regulator is shot.
The numbers on it are; 1119 165E and 12VN 6J
I think the (12VN) is 12 volt negative ground
Questions are,
is it the correct regulator,
if not, what is correct,
or, is there a better replacement known through experience?
thanks
walt
#2 olcowhand ONLINE
  • 36,474 Thanks
  • 30,061 posts
Posted October 18, 2010 - 12:55 PM
Any of the following should be a fit.
BRIGGS & STRATTON 295924
CUB CADET IH-545130-R93
CUB CADET 545130-R93
DELCO 1118988
GRAVELY 007275
JACOBSEN 107927
TECUMSEH 32089
435-040 / 1297 / GDR600
#3 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted October 18, 2010 - 06:15 PM
Gee, that was easy. The only one not listed was the one I had.
I was looking on Ebay before I posted and saw prices for similar up to $75
Let's hope the starter/generator is good.
Thanks
walt
#4 olcowhand ONLINE
  • 36,474 Thanks
  • 30,061 posts
Posted October 18, 2010 - 06:49 PM
Go here, $33.90 shipped to your door!
Cub Cadet Electrical Parts
#5 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted October 19, 2010 - 01:25 PM
I looked at the site yesterday, thanks.
Now, One of the regulator terminals went to ground, which I'm almost sure was wrong.
I worked up a drawing from several sources which should be right for what I want.
How'd I do??
My ignition switch is just a toggle from the mag to ground.
#6 MH81 ONLINE
  • 28,370 Thanks
  • 29,096 posts
Posted October 19, 2010 - 08:25 PM
Is the jumper from batt to gen terminals right? I don't remember that wire there & mine was working fine.
#7 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted October 19, 2010 - 08:34 PM
That jumper is supposed to polarize the regulator, and I am (not) sure about it. Saw it in a video on youtube.
And from auto experience, I know the regulator should be mounted first, the battery ground connected as usual next, and then the rest of the wiring in any order... because, just swapping a regulator and mounting it, (grounding it last), can ruin it in one second's time.
#8 DH1 ONLINE
DH1
    Electric Tractors
  • 4,681 Thanks
  • 5,334 posts
Posted October 19, 2010 - 08:47 PM
This is what I used to wire up my Massey MF10s starter generator and it seems to work fine.
Here's a link to some more info. STARTER-GENERATOR WIRING DIAGRAM
#9 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted October 19, 2010 - 09:28 PM
I was at this site this morning and took some from it. I don't need the key switch or solenoid. The starter button in mine was new when I got it and is heavy duty... I don't have the new regulator yet. The one I'm looking to buy doesn't have the "L" terminal for loads, but is like the one in my drawing.
Thanks
walt
