Junkyard 318
10 replies to this topic
#1 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted April 17, 2013 - 04:41 PM
seen a 318 at the scrap yard today that was complete . hood was busted up but engine had compression on both cylinders by just turning the flywheel had wheel weights good tires . i ask what it would take to get it out of there and it will cost .36 cents a pound bout $360.00 . still thinkin bout it .
  • JRJ said thank you
#2 collinmf12 OFFLINE
collinmf12
  • 114 Thanks
  • 197 posts
Posted April 17, 2013 - 04:48 PM
Well, im not a john deere fan but my dad is and if my dad seen that deal it would be home with us right know.
#3 jdslednut OFFLINE
jdslednut
  • 637 Thanks
  • 837 posts
Posted April 17, 2013 - 05:37 PM
If all else fails, you could probably get $300 by parting out the hydraulic system alone.  I say go for it.
#4 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted April 17, 2013 - 05:45 PM
i was just on ebay and i can get my money back easy enough just dont know anything about the tranny and hydro pump thats what has me worried . dont want to sell someone junk .
#5 dodge trucker OFFLINE
dodge trucker
  • 1,490 Thanks
  • 1,942 posts
Posted April 17, 2013 - 09:03 PM
those tractors weigh 1,000 lbs?  I think your estimate on weight is high unless the tires are filled with concrete or lead
Edited by dodge trucker, April 17, 2013 - 09:03 PM.
#6 Sandburr OFFLINE
Sandburr
  • 35 Thanks
  • 46 posts
Posted April 18, 2013 - 07:39 AM
The wheel weights are worth $150 - 175.00 a pair alone.
#7 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted April 18, 2013 - 02:49 PM
Weight: 836 lbs [379 kg]
tractor 836 + wheel weights 75 lbs x 2 = 986 x .36 cents = $ 354.96 . seems pretty damn close to me .
#8 Guest_gravely-power_*
  • Guests
Posted April 18, 2013 - 03:21 PM
I sure would drag it home.
#9 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 96 Thanks
  • 348 posts
Posted April 18, 2013 - 10:52 PM
Actually, if it was me, and I am a die hard IH guy, that though would be home in my garage right not. Provided I had the money and the transportation
#10 dodge trucker OFFLINE
dodge trucker
  • 1,490 Thanks
  • 1,942 posts
Posted April 19, 2013 - 06:10 PM
wow I would have guessed ~650-ish lbs
#11 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,028 Thanks
  • 1,455 posts
Posted April 19, 2013 - 08:08 PM
I would say go for it too. Like the other guys said, if worse comes to worse you can part it out and get your money back.
