Bolens G152 48" Mower Deck Redo
bolens iseki g152 model 1349 48 mower deck
24 replies to this topic
#16 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted April 26, 2013 - 10:00 AM
Yep, I got grinding rust down to a science.
#17 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted May 01, 2013 - 09:04 PM
I need some help. I can't find the proper size replacement idler pulley for this deck. I need two flat (with edging) idler pulleys. 5" diameter, 5/8" or 1/2" bore, 3/4 width were the belt runs. Steel, not nylon or plastic.
132946314_-lawn-mower-idler-pulley-repla
The deck is all painted up. I'm going to let it cure until the weekend or so, then hopefully have it put together and put on the tractor when the decals arrive.
#18 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted May 10, 2013 - 01:15 PM
It's all back together, might put it on the tractor tomorrow.
#19 NJKen OFFLINE
NJKen
  • 1,362 Thanks
  • 1,284 posts
Posted May 10, 2013 - 03:23 PM
Looks great Scott !! Nice and shiny !!
Now, can you straighten out those cockeyed tool cases hanging the wall ? Hope your not the one hanging the artwork in the house.
#20 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted May 10, 2013 - 03:53 PM
Well now that's almost too purty to mow grass with!!
#21 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted May 15, 2013 - 09:40 PM
On Monday, before I left, I did put the deck on and mow a small area with it. The mail arrived while I was doing that, and I got the decals for the G152. The decals look good, and it mowed very well even at half throttle.
Won't have pics anytime soon. I will only be home for 18 hours this weekend and plan on going to a Twins baseball for 5 of those.
#22 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted May 19, 2013 - 12:21 AM
Just got home, couple of quick pics in the garage.
#23 KennyP ONLINE
  • 41,485 Thanks
  • 47,409 posts
Posted May 19, 2013 - 06:34 AM
Looking good in there! Glad you got back to work!
#24 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted March 26, 2016 - 03:10 PM
After buying a Simplicity with a 48" deck for mowing duties, I have been looking for another option to mow with. The Bolens does a fine job, but the 48" deck barely covers the width of the tractor. Not to mention it is a SCUT, so the turning radius is not real tight. I have 2.5 acres, with lots of trees to mow around. With the 48" deck and a manual transmission, it took a long time to mow the yard.
The Simplicity front mount mower is okay, but needs a rebuild in several areas including a weak hydro.
I also have got a GT  with a 60" deck, that needs a stem to stern rebuild. The Onan in it needs work, and I'm still scavenging/saving up for that.
So, I have been looking for a bigger deck for the Bolens and I think I found one. More to come later, I hope.
#25 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted March 26, 2016 - 09:25 PM
New thread soon:
  • Bolens 1000 and Cvans have said thanks
Also tagged with one or more of these keywords: bolens, iseki, g152, model 1349, 48 mower deck
