Bolens G152 48" Mower Deck Redo
bolens iseki g152 model 1349 48 mower deck
24 replies to this topic
#1 Cat385B ONLINE
    HAZMAT CAT
  • 14,012 Thanks
  • 10,013 posts
Posted April 17, 2013 - 11:44 AM
Since winter won't release it's death grip, I might as well tear into the mower deck for my diesel G152. I have no plans to use this as a mower unless the Jacobsen would happen to break down.
Overall, it's in decent shape. It turns, but awfully stiff. One half of the pto knuckle that attaches to the tractor is gummed up, and the blades all have resistance. The gearbox seems to be fine.
There is a patch welded to the front edge of the deck, I'll grind it off to see why it's there.
The blah-blah-blah decals are shot, the important ones and the tag are in good shape.
  • hamman, boyscout862, aliciakn2 and 3 others have said thanks
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 17, 2013 - 11:53 AM
Looks like its in decent shape.
It may be something simple like a seized idler pulley causing the resistance.
#3 Cvans ONLINE
  • 6,668 Thanks
  • 6,134 posts
Posted April 17, 2013 - 11:55 AM
I have to give Bolens credit for having the cutting line marked on their decks. I don't know why more manufacturers don't do that.
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,012 Thanks
  • 10,013 posts
Posted April 17, 2013 - 12:14 PM
JD used to put a width of cut sticker on their decks.
  • Cvans said thank you
#5 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,487 Thanks
  • 5,777 posts
Posted April 17, 2013 - 12:51 PM
Still looks pretty solid!  Tear into the spindles and find the problem..  Might be as easy as over-torqued blades?? :smilewink:
(Somebody else 'puddle-jump welds' like me!! :thumbs:
#6 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted April 17, 2013 - 01:48 PM
Hey cat i have the decals for that deck and the one that is faded out on the other side said no step if i remember right.
  • Cat385B said thank you
#7 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,440 Thanks
  • 2,861 posts
Posted April 17, 2013 - 02:11 PM
Nice looking deck cat ! Looks like you are doing it right as you always do. Looking forward to the redo. Roger.
#8 Cat385B ONLINE
    HAZMAT CAT
  • 14,012 Thanks
  • 10,013 posts
Posted April 19, 2013 - 06:12 PM
Underside of the deck, center, in the back are two metal tabs. Do they hold an anti-scalp roller? If so, what is it's diameter? The tabs are just over 5" apart. I'll turn down a piece of southern yellow pine if I know what size to make it.
#9 Cat385B ONLINE
    HAZMAT CAT
  • 14,012 Thanks
  • 10,013 posts
Posted April 19, 2013 - 06:24 PM
Got it torn apart this afternoon, grinding off the front patch now.
#10 Cat385B ONLINE
    HAZMAT CAT
  • 14,012 Thanks
  • 10,013 posts
Posted April 19, 2013 - 06:32 PM
Uh oh, work is halted. I'm out of beer! All that's in the fridge is bottled water! Says Coors Light on the label, tastes like soup made with Daniel's work boot.
#11 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 19, 2013 - 06:35 PM
I'm a bit confused. I'd read somewhere, you don't have a GT. But you obviously
do have a deck.
I guess, we all had to start somewhere.
I hope you can find the right machine for your deck, so you can test it. :smilewink:
#12 Cat385B ONLINE
    HAZMAT CAT
  • 14,012 Thanks
  • 10,013 posts
Posted April 19, 2013 - 08:25 PM
I still think we should have a 'thanks for nothing' button.
The deck is fine underneath that patch. Included in the literature I got with the Bolens was a book for a Lambert vac system. So the white bracket on the deck was for that, and I think the metal was added to the deck to increase the suction.
  • IamSherwood said thank you
#13 Cat385B ONLINE
    HAZMAT CAT
  • 14,012 Thanks
  • 10,013 posts
Posted April 26, 2013 - 09:01 AM
I'll be throwing color on it tomorrow. For something I'll probably never use, I'm sure sticking a lot of time into this.
#14 NJKen OFFLINE
NJKen
  • 1,361 Thanks
  • 1,284 posts
Posted April 26, 2013 - 09:04 AM
It's a labor of LOVE Scott !! Plus your weather sucks, your laid off and your bored.
#15 Guest_gravely-power_*
  • Guests
Posted April 26, 2013 - 09:29 AM
Looks nice. Just think of all the experience you just got. Makes the old resume' look good.
Also tagged with one or more of these keywords: bolens, iseki, g152, model 1349, 48 mower deck
