John Deere 400
23 replies to this topic
#1 Jay317 OFFLINE
Jay317
  • 1 Thanks
  • 4 posts
Posted April 16, 2013 - 08:19 PM
Hi and thanks for having me on this wonderful site I acquired a JD400 which has a CAT 0 3 point hitch...My question is how can I convert the 3 point hitch to a CAT 1 because it seems hard to find Cat 0 rear attachments and thanks again for having me
  • JRJ said thank you
#2 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted April 16, 2013 - 09:13 PM
Jay317, :welcometogttalk:  Glad you decided to join. On your 400, I think you would find it easier to change your implements from Cat. 0 to Cat. 1. If you change your tractor over, you will end up having to change your 3 point arms.
  • Jay317 said thank you
#3 boyscout862 ONLINE
  • 12,850 Thanks
  • 9,171 posts
Posted April 16, 2013 - 09:20 PM
Welcome to GTT.
#4 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted April 16, 2013 - 09:38 PM
a cat.1 spread is 27" a cat. 0 is 20" . i think if you spread your 3 point arms out to 27" you will have a clearance problem between the arms and tires . i think what LTD meant was change your cat 1 implements to cat 0 . and that could be difficult on some implements . there is alot of cat.0 implements around for sale but it will most likely be used . there are some new cat.0 implements you can buy . welcome to GTT and congrats on the 400 they are pullers .
http://www.northernt... hawklinebehlen
Edited by Gary400, April 16, 2013 - 09:44 PM.
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,771 Thanks
  • 4,263 posts
Posted April 16, 2013 - 10:41 PM
:welcometogttalk:
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted April 17, 2013 - 12:45 AM
:welcometogttalk: :wewantpics:
#7 Jay317 OFFLINE
Jay317
  • 1 Thanks
  • 4 posts
Posted April 17, 2013 - 02:20 AM
Thanks for the kind words!!!!
#8 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 17, 2013 - 05:14 AM
Welcome to GTTalk. The newer large JD GTs like the x700 series do have a limited Cat1 3 point hitch. The limited refers to the lift being less than a full cat 1. I had one on an X475. The arms were bent in such a way to clear the 26x12/12 tires and still allow for a full width cat 1 implement. Heres a picture of a cat 1 dirt scoop on the 475. I don't know if you could make a similar set of arms to work on a 400 but it is a possibility. I have better pictures of the arms but don't have access to them now. If you want to see them just let me know.
#9 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted April 17, 2013 - 08:34 AM
Welcome to GTTalk, if it is made for a tractor, the men here will know all about it and how to use it and how to modify it.
Dick.
#10 olcowhand OFFLINE
  • 41,148 Thanks
  • 31,416 posts
Posted April 17, 2013 - 10:28 AM
You could always build a quick attach adapter.  Just an A frame that attaches as a normal cat 0, but with quick attach brackets on it's rear to attach to the Cat 1 implement.
#11 Jay317 OFFLINE
Jay317
  • 1 Thanks
  • 4 posts
Posted April 17, 2013 - 11:34 AM
Where can I buy the adapter at???,thanks
#12 olcowhand OFFLINE
  • 41,148 Thanks
  • 31,416 posts
Posted April 17, 2013 - 12:33 PM
That would have to be a custom built item.  I've never seen them offered, but know it could be built.
#13 Jay317 OFFLINE
Jay317
  • 1 Thanks
  • 4 posts
Posted April 17, 2013 - 12:56 PM
I wish I had the skills to do so..lol..lol
#14 SamMC OFFLINE
SamMC
  • 209 Thanks
  • 176 posts
Posted April 17, 2013 - 01:16 PM
Jay, first, welcome to the site. Second, I understand your issues with finding cat  0 stuff. I use a converter A frame and run sleeve hitch attachments. The sleeve hitch stuff isn't too expensive and your tractor will handle it nicely. Just a thought.
#15 SamMC OFFLINE
SamMC
  • 209 Thanks
  • 176 posts
Posted April 17, 2013 - 01:21 PM
Here is the one I use:
http://www.ballardfabrication.com/
