Vegetable Oil As Motor Oil
18 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted April 16, 2013 - 07:41 AM
im working on my senior project which i present tomorrow.  I came across people using vegetable oil in place of motor oil.  Im goin to try it in a old honda mower i have and see if it works.  If it does it will be part of my presentation tomorrow. any ideas if it will work
  • JRJ said thank you
#2 Alc ONLINE
  • 6,896 Thanks
  • 7,466 posts
Posted April 16, 2013 - 07:53 AM
At work about 20 years ago they tried vegetable oil based hydraulic fuild with the thinking of it less costly for any clean up issues , to me it seem as it got hot from use it left a think film on the cylinder rods ( think of a Fry Daddy ) and in time damaged the seals , we had so many cylinder go bad , hyd. tools ect. we ended up swapping it out for regular hydraulic fluid , but for  the fun of it give it a try , Al
  • Newpaws493 said thank you
#3 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted April 16, 2013 - 07:55 AM
i ran the motor with a mix of conventional and vegetable oil yesterday. it ran fine with no issues.  Hopefully straight vegetable works just as good. its only goin to run for a minute or two
#4 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,176 posts
Posted April 16, 2013 - 08:13 AM
I think that the vegetable oil will break down fairly quickly. It will lead to engine failure. I may be an interesting experiment with a mower engine to see how long it will work. Making a biodiesel fuel is an interesting idea if you have lots.
Edited by boyscout862, April 16, 2013 - 08:14 AM.
  • HDWildBill and jd.rasentrac have said thanks
#5 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted April 16, 2013 - 08:14 AM
That's what I like a person willing to take a chance, like you said give it a try. The heat would be your main concern and if used for a long period of time, then the interior of the motor would have to be checked to see how it was holding up.
Dick
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 16, 2013 - 08:31 AM
You could be opening up a can of worms, but it would be worth researching and experimenting with.
From watching cooking shows with the wife, it seems that vegetabe oils made from various products have different temperatures where they begin to burn. So you might want to investigate that and look especially at devising a method of checking oil temps while the engine is operating. And the Flash Points of the oils. It could work or go "up in smoke"? Don't be afraid to experiment, I think it was Thomas Edison who said he had Not failed, he had found 1000 way not to make a lightbulb. But eventually he did it and the rest is history.
Edited by JD DANNELS, April 16, 2013 - 08:34 AM.
  • HDWildBill, boyscout862 and Newpaws493 have said thanks
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted April 16, 2013 - 08:34 AM
As said before, it may work a short time. In petrol based oils you'll find additives. Vegetable oil will burn down and the grease is gone. I can better explain it in german :smilewink:
#8 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted April 16, 2013 - 10:12 AM
There are successful bio-based engine oils out there, G-oil being the first one that comes to mind. However, the starting "bio" stock is really just used as a source of carbon chain molecules to be ripped apart and put back together as a synthetic oil. G-oil actually uses beef tallow as their starting point.
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 16, 2013 - 10:34 AM
Research this first before wrecking a good motor. This has probably been done many times. If so, you want to try adding to that research in some way by performing a different experiment instead of repeating what's already been done.
#10 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted April 16, 2013 - 03:22 PM
peanut oil will take more heat when used for cooking dont know about in a engine .
#11 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted April 16, 2013 - 03:34 PM
One thing to remember is cost,
  difference between a gallon of cooking oil vs: motor oil isn't worth the damage that will happen, sooner or later.
#12 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,337 Thanks
  • 4,957 posts
Posted April 16, 2013 - 06:08 PM
Some of my co-workers think motor oil is optional anyhow  :deadhorse:
#13 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted April 17, 2013 - 07:27 AM
well it seems to run fine.  I got the presentation today at 10am im so nervous
#14 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 17, 2013 - 08:21 AM
I'm sure you will do just fine.  Take some deep breaths just before it's your turn.
#15 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted April 18, 2013 - 07:24 AM
well i passed the project and the mower ran fine.  I can finally say I can graduate from highschool
  • Alc, KennyP, HDWildBill and 1 other said thanks
