Massey 10 Tecumseh Camshaft Problem
17 replies to this topic
#1 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted April 15, 2013 - 08:36 PM
I have a Tecumseh HH100 in the Massey 10 that I recently purchased. Previous owner changed the engine to a HH100 from a Wheel Horse Charger . I also received the original engine. The wheel Horse engine was a solid state while the original engine was a oints engine. Due to block issues the original is not usable. However, they are almost identical engines, so i decided to change the back covers so the wheel horse engine could be a points engine. then I can change the front covers and use the original cover with the belt guard for the starter generator. The only problem is that the cam needed switched, which was not a problem, BUT the points engine cam has a tooth missing. Is this a major problem? Problem is that I havent been able to find a cam for a points engine. Any thoughts????
  • JRJ said thank you
#2 olcowhand ONLINE
  • 41,274 Thanks
  • 31,449 posts
Posted April 15, 2013 - 08:40 PM
Do NOT use the camshaft with a tooth missing!  You will end up destroying the crank teeth as well.  Early 67 & older HH cam is what you need.
#3 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted April 15, 2013 - 08:46 PM
so any idea where I can come up with one? been lookin on ebay, but am unsure which one is what I need.
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted April 15, 2013 - 08:57 PM
I found there are cams with straight gears and angle gears.
The cam on the right is a points cam.
#5 olcowhand ONLINE
  • 41,274 Thanks
  • 31,449 posts
Posted April 15, 2013 - 09:01 PM
Can you post a good pic of yours?  Some have straight cut gears, others helical.  Edited:   Doug beat me to posting
#6 olcowhand ONLINE
  • 41,274 Thanks
  • 31,449 posts
Posted April 15, 2013 - 09:04 PM
Contact our site sponsors.  Bob's Lawn & Garden is a great source.
#7 philips100 OFFLINE
philips100
  • 72 Thanks
  • 82 posts
Posted April 15, 2013 - 09:16 PM
What are the differences in the "points" cam and the "solid state" cam?
#8 olcowhand ONLINE
  • 41,274 Thanks
  • 31,449 posts
Posted April 15, 2013 - 09:18 PM
Doug, this cam on ebay has the area machined for the points cam, plus the notch for the cam limiter.  I think if this cam were to be drilled accurately for the pins, one could transfer the points cam assembly over to this one.  Pricey, but if the only option...
http://www.ebay.com/...=item35c6488d52
#9 olcowhand ONLINE
  • 41,274 Thanks
  • 31,449 posts
There is no cam lobe to operate the points or advance/retard the ignition timing.
#10 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted April 15, 2013 - 09:23 PM
DSCF5346.JPG DSCF5347.JPG Ok, here are pics of what I have. Apparently there is another problem. one of the pins for the plate on the front is missing.
#11 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted April 15, 2013 - 09:26 PM
BTW, this is from a HH100-115033A Serial #6348  12689. Thanks for all the replies!
#12 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted April 15, 2013 - 09:34 PM
So I looked on ebay and found #370773760198. Is this what I need?
#13 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted April 15, 2013 - 09:41 PM
I think that's what your looking for
straight tooth, with decompressor and points cam.
#14 DH1 ONLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted April 15, 2013 - 09:43 PM
You could be right???
#15 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted April 15, 2013 - 09:49 PM
I think im gonna put in an offer on the ebay one I referenced. Still cheaper than dealing with the solid state!
