Ford Starting Issues!
16 replies to this topic
#1 KennyP ONLINE
  • 40,925 Thanks
  • 47,121 posts
Posted April 15, 2013 - 04:52 PM
My closed side decided it wanted a break and refuses to start. Got 12V to the coil and going to the points. Just no fire at the plug!  Can't check them until I remove the rear PTO shaft. So I just bit the bullet and bought a tuneup kit from Tulsa Engine Warehouse. That comes with points, push rod, condenser, and plug. Also got a new coil just for the heck of it. Just a tad over $50 for all including shipping. When they get here, I'll start taking things apart.
  • boyscout862 and JRJ have said thanks
#2 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,178 Thanks
  • 2,256 posts
Posted April 15, 2013 - 05:09 PM
Sorry to hear you are having a problem.  Electrical can be a real P.I.T.A.   I remember as a teenager being embarrassed when my grandmother handed me an emery board , told me to file the points and change the condenser.  She was right. But of course she had learned the hard way also.   Good luck  Rick
  • 14,889 Thanks
  • 15,514 posts
Posted April 15, 2013 - 05:11 PM
Kenny, I would keep the points with emery cloth and see what that does for yah.
#4 KennyP ONLINE
  • 40,925 Thanks
  • 47,121 posts
Posted April 15, 2013 - 06:45 PM
Won't know anything till I can get in there. But, with the PTO shaft where it is, I'll probably just put the new stuff in and go from there. Don't need to do this too often. It'll take probably an hour and a half just to pull the shaft and get it lined back up right. It could be the push rod is stuck and not letting the points close!
#5 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted April 15, 2013 - 10:24 PM
Just for the heck of it try the new plug first. Good Luck, Rick
#6 KennyP ONLINE
  • 40,925 Thanks
  • 47,121 posts
Posted April 16, 2013 - 02:34 AM
Good idea! I will also unhook the points from the coil and momentarily ground the - on the coil to see if it sparks.
#7 Alc ONLINE
  • 7,230 Thanks
  • 7,581 posts
Posted April 16, 2013 - 05:55 AM
Kenny I know what you mean about if you have to tear an hour into something just to test it you might as well just replace it , then hopefuly it's good for a long time
#8 KennyP ONLINE
  • 40,925 Thanks
  • 47,121 posts
Posted April 16, 2013 - 06:45 AM
That's my thoughts, Al. I could smooth and reset the points, but how long before I have to do it again? The Ford has done real well since I put rings in it, Not sure how many hours I have on it. That analog hour meter is hard to read.
#9 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted April 16, 2013 - 11:03 AM
 Nevermind puttin the pto shaft back on... I need to borrow your front pto brackets for a short spell :big_hug:
#10 KennyP ONLINE
  • 40,925 Thanks
  • 47,121 posts
Posted April 16, 2013 - 12:46 PM
Thanks for reminding me! I had forgotten!
#11 KennyP ONLINE
  • 40,925 Thanks
  • 47,121 posts
Posted April 16, 2013 - 01:41 PM
Boy! Those folks a Tulsa Engine Warehouse are fast. I ordered the parts yesterday morning. Got them in today's mail. That's quick!
Now to get the weather to cooperate. We have a cool NW wind and drizzle right now. Too chilly for me to lay down and take the PTO off!
  • JRJ said thank you
#12 KennyP ONLINE
  • 40,925 Thanks
  • 47,121 posts
Posted April 17, 2013 - 05:50 PM
Found the issue! Wire to points! The connector had given up right where it attaches to the points. Put a new one on and all is well!
#13 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted April 17, 2013 - 06:20 PM
Glad to hear you got the problem fixed without to much fuss.
Dick
#14 Rock farmer OFFLINE
Rock farmer
  • 1,299 Thanks
  • 1,274 posts
Posted April 17, 2013 - 07:05 PM
Good news!
But, you had to pull the PTO shaft back to find it? Have you considered a solid state points eliminator for that tractor?
Joe
#15 KennyP ONLINE
  • 40,925 Thanks
  • 47,121 posts
Posted April 18, 2013 - 01:14 AM
Good news!
Joe
Sure did today, Joe! I need to look into that a bit closer. Got any info?
