This Could Be The Ultimate Zero Turn.
This topic has been archived. This means that you cannot reply to this topic.
11 replies to this topic
#1 Cvans OFFLINE
  • 6,648 Thanks
  • 6,129 posts
Posted April 14, 2013 - 11:20 PM
http://www.ebay.com/...=item2329d832ab
#2 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted April 14, 2013 - 11:39 PM
Darn, and I was just in Chicago today, might just have to look into that machine.
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted April 15, 2013 - 12:47 AM
I find it funny someone wanted to do a trade :rolling:
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 15, 2013 - 04:59 AM
That's a serious mower. 60hp!!! It looks well maintained and 1930 hrs is not a lot for a diesel.
#5 Cvans OFFLINE
  • 6,648 Thanks
  • 6,129 posts
Posted April 15, 2013 - 09:00 AM
I know if I had a use for it I'd be on it like stink.
#6 MailmAn OFFLINE
MailmAn
  • 334 Thanks
  • 741 posts
Posted April 15, 2013 - 10:42 AM
Wow, that thing is awesome.  Too bad I don't have a yard big enough to even park that monster in, let alone actually use it!  Although, I suppose if I could get it in my yard, all I'd have to do is start it up, spin it around once 360 degrees, and I'm done mowing!  lol...
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 15, 2013 - 12:35 PM
Hmm I wonder if I could even get it up to normal running temp on 8 acres?
#8 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted April 15, 2013 - 12:52 PM
I would think that thing wouldn't need more than 40 hp, seems to be a lot of ponies for mowing 7 feet wide.
#9 olcowhand OFFLINE
  • 41,194 Thanks
  • 31,428 posts
Posted April 15, 2013 - 02:25 PM
My JD F935 is 22hp diesel, and it mows a 72" swath with ease.  BUT, all the hydraulics that machine has sucks up several ponies.  Still, 60hp seems a bit much.
#10 MailmAn OFFLINE
MailmAn
  • 334 Thanks
  • 741 posts
Posted April 15, 2013 - 05:58 PM
Hey, nothing wrong with a little overkill!  You're right though, everything on this machine in hydraulically driven, so the engine isn't doing anything but running a hydraulic pump, basically.  That must be one hell of a pump though that requires 60HP!  The blades aren't even run off of the engine though, they are hydraulic as well.  The drive wheels, the steering, the lift mechanism, etc...  it is all run by hydraulics.  I'd hate to see the repair bill to replace hoses on this thing though once they start to leak!
#11 UncleWillie OFFLINE
  • 15,676 Thanks
  • 8,763 posts
Posted April 15, 2013 - 07:14 PM
IF it is built by Puegoet it will need every extra pony it can get since they are French ponies and will surrender at the first sign of trouble.
#12 Cvans OFFLINE
  • 6,648 Thanks
  • 6,129 posts
Posted April 15, 2013 - 10:08 PM
I can't imagine the amount of heat that hydraulic system generates. My neighbor has a large Toro (I think) mower with three decks and everything on that is hydraulic also.
