Bush Hog Hd-12 Hydro Or Engine Doesn't Seem Right
bush hog hd-12 hydro transmission
50 replies to this topic
#46 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted April 17, 2013 - 11:17 AM
I don't think I will have time to tinker tonight because of staying at work late doing software updates. I should be able to get home on Thursday at normal time and I will get a timing light or the meter on it and check the timing.
I triple checked the timing dots on the cam and crank when I put the motor back together.
  • olcowhand said thank you
#47 olcowhand ONLINE
  • 40,374 Thanks
  • 31,177 posts
Posted April 17, 2013 - 11:19 AM
I figured you checked all that close, but thought I'd make mention.  On my dirt bike, having a cam chain made it less simple to be sure all is aligned.
#48 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted April 17, 2013 - 01:53 PM
I am anxious to dig in to it some more. I would love to do a diesel or another engine swap but I would much rather save the money towards getting a bigger truck with more cab space. Hopefully it does turn out to be timing issues and nothing else. As long as it will spin the trail mower without killing it than I will be fine. It did alright plowing. Just couldn't push it too hard.
#49 olcowhand ONLINE
  • 40,374 Thanks
  • 31,177 posts
Posted April 17, 2013 - 01:57 PM
George, maybe the camshaft is in backwards, or you didn't get the cam lobes locked down tight!    :smilewink:   But on a serious note.....could there be blockage in the muffler?   That will sure stifle an engine....bad!  By the sound it's open, but just a thought.
#50 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted April 17, 2013 - 02:35 PM
I am going to go with something fuel/air related. I have a onan that does something similar, runs great and acts ok until there is a heavy load. Then it bogs down bad. How do I know its it mix related (on my onan) you can turn both adjustment screws all the way in and it still runs ok.
Try making half turns on the hi side screw and see if it makes a difference in the bogging.
#51 DH1 ONLINE
DH1
    Electric Tractors
  • 5,243 Thanks
  • 5,552 posts
Posted April 17, 2013 - 04:56 PM
:ditto:
 If the timing checks out to be good or after you reset it there is not much improvement then restricted exhaust would be the next thing to check, as said above.
Larger dia exhaust pipe and elbows right from the motor, 1 size up.
Check or replace the muffler with one that can handle the exhaust flow from the engine.
Also tagged with one or more of these keywords: bush hog, hd-12, hydro, transmission
