1968 John Deere 110 8hp Kohler Drive belt, variator
8 replies to this topic
#1 ljgalemd OFFLINE
ljgalemd
  • 2 posts
Posted October 16, 2010 - 06:13 PM
My variator handle does not engage anything, does anyone have a diagram of the pulley/spring system?
Thanks, Luke
It's not in my book.....arrrrrrrgghhh!
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted October 16, 2010 - 07:39 PM
Welcome to GTT, Luke :wave:
Be sure to visit our JD forum. Someone should be along soon to help you out.
#3 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted October 16, 2010 - 09:15 PM
Check out the service manual located here...
200 series service manual - Manuals - Garden Tractor Talk
It's for the 200 series but the 100 series is similar. Maybe it will give you some ideas.
#4 ljgalemd OFFLINE
ljgalemd
  • 2 posts
Posted November 03, 2010 - 12:14 PM
The download link is invalid...keeps giving me a security token message???
#5 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted November 03, 2010 - 12:19 PM
I just tried it and it seemed to work. Maybe George (site moderator) can look into the problem for you.
#6 JDMonnell OFFLINE
JDMonnell
  • 2 posts
Posted March 11, 2011 - 05:14 PM
I have a 72' with the same problem -- did you figure out if it was the spring? I want to fix it before mowing season starts up so any pointers you have would be appreciated. JD.
#7 MH81 OFFLINE
Posted March 12, 2011 - 09:15 AM
You might want to look at the above mentioned manual. Also, you might check out the manual on the MF10/12 as it is a similar unit. Not exact tho... They used the "seconds" on the green tractors. Just kidding, Someone smarter than I will have to tell you how similar they are, but it would be worth a look IMO.
  • JDMonnell said thank you
#8 dcso600 OFFLINE
dcso600
  • 7 posts
Posted April 08, 2011 - 03:14 AM
If the belts are good, may just need to adjust the variator. On the right side under thevatitor handle there should be a couple of caps. remove the toward the front of the tractor. there will be a 3/4" cap screw on the variator at this point. remove the spark plug wire, place the variator handle al the way forward(fast position), loosen the capscrew and crank the engine. watch the clutch pedal, when it stops moving to the raised position, tighten the capscrew. This should fix the problem unless the variable drive center sheave is not moving freely.
hope this was not confusing.
#9 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted April 09, 2011 - 08:41 AM
Also make sure you are using John Deere belts and not some off brand. Deere belts and pulleys use a different angle degree so you will run into to a lot of problems if you don't use them.
