Modifying Belt Driven Snow Blower To Shaft Drive
23 replies to this topic
#1 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted April 14, 2013 - 02:54 PM
Hello Guru's:
I live in Canada so the model numbers of my equipment may differ from yours.
I have a
MTD 190-621, 42 inch 2 stage blower
It was originall ordered for a White (MTD) LT-185.
I mounted it to a Craftsman LT4000 model 944.604250 looks identical to 917.257660.
I "farmicated" the two together but belt tension and alignment were not perfect.
long story short, cost me $100.00 to replace the belt and that belt lasted 2 hours before shredding.
my thoughts.............
MOVE SOMEWHERE WITHOUT SNOW. ( no such place in Canada)
SNAP KEY OFF IN GARAGE DOOR AND LIE TO NEIGHBORS THAT IT WON'T OPEN UNTIL THE SNOW IS GONE.( all 4 neighbors are widows)
HIRE SOMEONE TO GET RID OF MY SNOW AND MY NEIGHBORS SNOW ( that would be embarrasing wouldn't it)
So instead i decided to STOP BUYING BELTS and devised the following plan.
Eliminate the long belt and go shaft drive.
Use a right angle gear box and a drive shaft with a U joints at either end .
Use the existing engagement carriage to engage the right angle drive via a short belt.
The U joint at each end allows the blower to be lifted while the shaft is spinning.
approximate cost
$30 per U joint X 2 = $60
$30 for a 3/4" keyed shaft (driveshaft)
Right angle gear box $100.00 ?????????
Time - no charge.
Should total under $200.00 or two belts and last for years.
Has any one done this?
Any thoughts or advice
  • JRJ said thank you
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 14, 2013 - 03:08 PM
:welcometogttalk: Welcome BigA! I haven't done a mod like that yet. It sounds like a great idea. I am sure someone will come along with advise. Good luck :thumbs:
#3 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted April 14, 2013 - 03:25 PM
Welcome to Gttalk I am Glad to see more and more Canadian people joining the forum I have a tread on making a berco fit on a shaft-drive tractor (http://gardentractor...for-tube-frame/ ) I chose not to look at the cost of a project but the Advantages of it If you need any help Feel free to Personal message me ... also pictures (if possible) tell a thousand words
Cheers
Ty
  • chris m said thank you
#4 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted April 14, 2013 - 03:44 PM
Welcome to GTTalk BigA, you have a very interesting project going on there, I wish you luck with it. If you run into problems I'm sure we have the men that can help you one way or another.
Dick
#5 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted April 14, 2013 - 07:56 PM
:welcometogttalk:    Sounds like you have put quite a lot of thought into this.
Good luck, and keep us posted (with pictures) of your progress.
#6 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted April 15, 2013 - 06:36 AM
Thanks for the warm welcome!
To go one step further in the "frugal" department, I would like to be able to complete this project with re-purposed parts.(read CHEAP).
Anyone know where a right angle gear box was used on an older tractor?
This is the costly part....
I saw one on a Massey Ferguson mower deck, but the owner was selling the deck complete as it was in great shape.
Any one have one stored and for sale, or know where i could find one?? :wave:  :wave:
#7 KennyP ONLINE
  • 38,274 Thanks
  • 45,881 posts
Posted April 15, 2013 - 07:01 AM
Welcome to the forum! Sounds like a neat project. The gearbox could be fun to find, especially one that turns the right direction. I thought about doing a shaft drive for a pull behind mower, but the gearbox was going the wrong direction. Good luck!
#8 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted May 22, 2013 - 03:25 PM
Hello Again GT Masters:
New developments...............
Craftsman tractor scrapped!
Sold the tractor but kept the blower.
Bought a Case 446, full hydro tractor.
Vertical shaft motor.
Snow blower needs to be modded to fit tractor.
Drive options:
I am still thinking shaft drive.
Now that I have hydraulics available I am bouncing the idea of a hydro enabled blower.
Your thoughts or ideas are welcome???
#9 MH81 OFFLINE
Posted May 23, 2013 - 07:29 PM
Since you have the 446 and it's increased capabilities, I would say that hydraulic is a good way to go.
  • IamSherwood said thank you
#10 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted August 06, 2013 - 03:18 PM
Problem 1 solved:
Found a Berco 48" blower on Kijiji. cant find a model number but it has the oil bathed rear gear box.
$200.00  :thumbs:  :thumbs:  :thumbs:  :thumbs:  :thumbs:  :thumbs:  :thumbs:
It is shaft drive and came absolutely complete with the optional electric lift cylinder included.
Problem #2
Spins in the wrong direction. :ah_shoot:
Have to sort that out.
#11 MH81 OFFLINE
Posted August 06, 2013 - 09:01 PM
Problem 1 solved:
Problem #2
Do you have a pic of the blower and tractor? Might be helpful for us to see the issue.
#12 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted August 07, 2013 - 07:08 AM
how do i post a pic?   :reading_the_manual:
#13 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted August 07, 2013 - 10:39 AM
okay sorted out the picture posting thing. :dancingbanana:
#14 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted August 07, 2013 - 11:09 AM
Pics of project
Backside of blower drive to blower
Front side of pulley drive to motor
Top view of drive
rear view of pulley drive
The tractor day of purchase
#15 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted August 13, 2013 - 02:41 PM
I thought this might work,
Your thoughts???
