Jd 300 Carburetor Float Valve Removal
float valve carburetor
10 replies to this topic
#1 purdum OFFLINE
purdum
  • 5 Thanks
  • 12 posts
Posted April 13, 2013 - 02:51 PM
I need to replace the float valve assembly in a JD 300 carburetor.  The float valve is easily removed but I can't figure out how to get the valve seat out (brass part, center of photo). It's a 3/8" threaded fitting but there's no room to even get a thin-wall socket around it.  I've tried putting a drill bit inside and backing it out, no dice.  Is there a special tool need to get the valve seat out?  My alternative seems to be to file down a bit of the carb body which forms the support for the float hinge pin just enough to get the thin-wall socket in.  Other ideas?
John Deere 300
16 hp Kohler K-341AQS engine, spec 71169A
Carburetor JD # AM35801 (Kohler # 4505308, pre-55000)
  • JRJ said thank you
#2 olcowhand ONLINE
  • 42,520 Thanks
  • 31,838 posts
Posted April 13, 2013 - 02:55 PM
I use a craftsman 1/4" drive 12 point socket....fits fine for me.  I would not remove any material from the carb body.  Maybe if you have one, take a cheap socket & grind the wall thinner.
#3 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted April 13, 2013 - 03:15 PM
I use the same socket Daniel (olcowhand) mentioned.
#4 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted April 13, 2013 - 03:25 PM
Same here, many of the cheaper sockets are to thick to work, I have many cheap tools that have been customized like Daniel said. :smilewink:
#5 purdum OFFLINE
purdum
  • 5 Thanks
  • 12 posts
Posted April 13, 2013 - 03:38 PM
Thanks.  I thought about this but the option didn't seem practical because I don't have any grinding machinery.  Maybe put the socket in a vise and attack it with a file....it's worth a try with a cheap socket.
I just wonder how the folks at the John Deere shop get these seats out.
#6 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted April 13, 2013 - 03:45 PM
They just use a thin wall socket. This is another reason I have so many of the same size sockets and wrenches. Even though they are the same size, they are all different in some way.
#7 purdum OFFLINE
purdum
  • 5 Thanks
  • 12 posts
Posted April 13, 2013 - 04:05 PM
I took the carburetor into an auto parts store and we tried a 3/8" thin-wall socket, but it didn't go down far enough to engage the hexagonal side of the valve seat.  There's only 1/16" clearance between the carb body and the edge of the seat.
#8 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted April 13, 2013 - 07:48 PM
If I don't have a socket, I can usually get them out with a wrench or a pair of large pliers. They aren't usually to tight. You probably don't want to use a file....unless you have plenty of spare time :rolling:
#9 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted April 13, 2013 - 07:51 PM
Oh and BTW :welcometogttalk:   Glad you joined the site. Thanks for the detailed description on the carb. That helps us out a lot. :thumbs:
  • purdum said thank you
#10 Ryan313 ONLINE
  • 3,404 Thanks
  • 5,241 posts
Posted April 13, 2013 - 08:06 PM
Welcome to the site!
I use a 1/4 drive deep socket like the others to get mine out.
#11 purdum OFFLINE
purdum
  • 5 Thanks
  • 12 posts
Posted April 17, 2013 - 07:49 PM
Thanks to everyone.  I found a 3/8" thin-wall socket that was able to engage the sides of the valve seat and remove it.  Back in business.
  • olcowhand and Alc have said thanks
