Handiest Attatchment.
8 replies to this topic
#1 Dave Central NY OFFLINE
Dave Central NY
  • 106 Thanks
  • 92 posts
Posted April 12, 2013 - 09:53 AM
Thought  I would show your a picture of the hadiest attachment I have for my 1614 with a three point hitch.POWER KING TRACTOR S 019.JPG
This lift is so handy, it's on the tractor  most of the time.  I've got 4 other tractors but none with the three point.
Is there any maximum amount of tractors allowed per acre ?
I just took the snowblower off this tractor , put it on a pallet , picked it up with this and moved it to summer storage. Later when the hay/ weeds get taller I'll use it to haul the sicklebar mower out to the garage  and mount it on this tractor.  I can use the lift on the tractor with the mower mounted by chaining the mower up. And the lift gets used a lot moving  pallets of implements around to a spot where they can be attatched easily.
If you want to build one here are some specs you need
Category 0 specs on the machine
Upper hitch point ......inside width.....2" outside width.....2 3/4" hole diameter.....5/8"
Lower pin dia........5/8" lower pin width.....20"
Mast height center of hole  to center of lower pins......13 3/4"
Edited by Dave Central NY, April 12, 2013 - 10:01 AM.
  • daytime dave, Alc, hamman and 6 others have said thanks
#2 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 12, 2013 - 10:39 AM
That looks good and I can see it's usefulness. I have not gotten around to it but want to build a carryall like that for my Ford.
#3 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,678 Thanks
  • 1,348 posts
Posted April 12, 2013 - 11:34 AM
Very nice!   :thumbs:   Would love to have something like that, but first need a tractor with a 3 point.
#4 daytime dave OFFLINE
  • 4,568 Thanks
  • 6,387 posts
Posted April 12, 2013 - 12:26 PM
Dave, that looks great.  I'll bet it comes in real handy.
#5 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted April 12, 2013 - 12:53 PM
No, you're allowed one tractor for each implement or attachment,.. plus a couple of spares.   :D
#6 Ryan313 OFFLINE
  • 3,241 Thanks
  • 5,159 posts
Posted April 12, 2013 - 02:49 PM
I have something very similar to that. Mine is not the right size to pick up pallets though, so I don't use it as much as you use yours.
#7 countryboy88 OFFLINE
countryboy88
  • 93 Thanks
  • 139 posts
Posted April 12, 2013 - 03:07 PM
#8 KennyP ONLINE
  • 32,740 Thanks
  • 42,347 posts
Posted April 12, 2013 - 07:00 PM
That's neat! Gotta have me one of them!
#9 pigsitter OFFLINE
pigsitter
    enjoyin the livin part of life!
  • 1,227 Thanks
  • 1,083 posts
Posted April 12, 2013 - 07:27 PM
Man,I like the way you think!! :thumbs:
