Jacobsen Oil Leak Fixing
jacobsen turfcat t422d
14 replies to this topic
#1 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,920 posts
Posted April 11, 2013 - 09:09 PM
I pulled the mower in tonight to start de-greasing. The hydro is slower than it should be by about half. Soaking now, clean tomorrow and inspect. Quite a few suspect joints and hoses. Eaton 11 hydro, btw.
  • JRJ said thank you
#2 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 11, 2013 - 09:28 PM
Good luck on the fixes! That's a cool looking mower :thumbs:
#3 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted April 11, 2013 - 09:51 PM
Nice machine for sure, hope you get the hydro up to snuff.
One of our parks departments here uses those, and I am always amazed at their ground speed while cutting.
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,920 posts
Posted April 11, 2013 - 10:00 PM
Mowing with it last fall, it cuts fine no matter the speed, as fast as you can go and stay on the seat works just fine. I have never seen a heavier mower deck than the one on this. It's thicker than most brush hogs.
#5 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted April 12, 2013 - 07:34 AM
that is one nice machine u got there. keep us posted on the fixes
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,920 posts
Posted April 12, 2013 - 02:10 PM
It's the fitting right out the top of hydro. 90 bend, suction hose attached to one end, threaded into the top of the Eaton 11 on the other. In between the bend and the nut on the threaded portion.
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,920 posts
Posted April 12, 2013 - 02:36 PM
Okay, what is that fitting above called? Having a heck of a time finding one identical so far.
#8 olcowhand ONLINE
  • 40,364 Thanks
  • 31,175 posts
Posted April 12, 2013 - 02:52 PM
Called:   Hydraulic. Connector steel hose barb 90 degree
Here's a whole page of them:  http://www.hydraulic...ta[grp_id]=4013
  • Cat385B said thank you
#9 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,920 posts
Posted April 12, 2013 - 03:35 PM
Always check the simple things first. O-ring replaced and it doesn't seem to be leaking anymore. Shortened up (cut off) another suction line that looked ratty at the clamp, and it seems to run stronger. (foot on tire test, it's still on the jack stands)
#10 olcowhand ONLINE
  • 40,364 Thanks
  • 31,175 posts
Posted April 12, 2013 - 05:50 PM
Front mowers are simply awesome!  I have a John Deere F935 with 6 foot cut deck and it'll go most anywhere.  I did however get stuck once.  Seems when you slip down a bank into 12" of sludge/mud/manure, they tend to get mired up....even with differential lock!  :smilewink:
  Yep, we have to replace o-rings under those type fittings a lot.  They come out looking like they are triangular o-rings.  I thought you meant it was leaking from where the tube goes into the body.
#11 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,920 posts
Posted April 12, 2013 - 06:07 PM
This one was just a bit thin in one area. Just enough, I guess. Dropped it off the jacks and spun around the driveway quick, it is faster. Lots more power in low gear also, it digs in when parked against a tree. Before, it would just sit. So, with new fluids and a good greasing it will get tomorrow night when I get home, it will be ready to hook up to the mower deck. At least 3 weeks before I need it though, four inches of snow on the ground yet.
Time to start planning the next project. If I can get a snowblower for this, I would sell the Bolens. I have a really bad idea rolling around in my head that someone should talk me out of. It includes a welder, metal, sprockets, and lots of head-banging. Finding a snowblower for this is tough, and bring good money. I see no reason why I couldn't build one. This is the design that I keep thinking about:
54_3col_REL022212prod_snow_6-1_lead-copy
#12 skyrydr2 OFFLINE
  • 3,870 Thanks
  • 3,403 posts
Posted April 12, 2013 - 07:11 PM
 Cool looking but the colors....... uggg .. LOL  Boy you better find some horse power for that thing !!!!!
#13 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,920 posts
Posted April 12, 2013 - 09:14 PM
Is this better?
If I were to attempt building something like that, it would have twin 24" fans, end up about 52"-54" wide I think.
#14 RedJake OFFLINE
RedJake
  • 23 Thanks
  • 23 posts
Posted April 30, 2013 - 02:34 PM
That's a nice machine you have there!
#15 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,920 posts
Posted May 10, 2013 - 02:27 PM
Mowed for a bit, hydro is still not up to full speed. No leaks that I can see. Back to the drawing board.
