1969 B10- Where To Get Parts
11 replies to this topic
#1 eriklane OFFLINE
eriklane
  • 10 Thanks
  • 40 posts
Posted April 11, 2013 - 07:45 PM
Just picked up a super nice B10, he says it needs a coil.  2 yr old motor, sharp all around, $450.  Where can I get a coil, assuming it needs one?
Saw a YT video, guy put an MSD ignition coil on one...lol.
  • Dieselcubmike said thank you
#2 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted April 11, 2013 - 08:06 PM
Welcome to GTTalk!
2 year old engine: what brand do we have?
Ben W.
#3 Newpaws493 OFFLINE
Newpaws493
  • 1,355 Thanks
  • 1,804 posts
Posted April 11, 2013 - 08:09 PM
:welcometogttalk:  Good luck findin what ya need. There's a member intro section and lots more to see around here.
#4 johndeereelfman OFFLINE
johndeereelfman
  • 5,709 Thanks
  • 2,597 posts
Posted April 11, 2013 - 08:14 PM
Welcome to GTTalk!
Ben W.
Should be a 10hp Briggs Ben. if it's original to the tractor.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,191 Thanks
  • 5,786 posts
Posted April 12, 2013 - 12:02 AM
:welcometogttalk: :wewantpics:
#6 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 9,442 Thanks
  • 5,247 posts
Posted April 12, 2013 - 01:30 AM
Welcome aboard!
Believe it or not Simplicity dealers are alive & well so take a look around ya..
The area seems to be innundated with dealers:  http://maps.google.c...Q&ved=0CIkBEMgT
#7 KC9KAS OFFLINE
KC9KAS
  • 5,161 Thanks
  • 4,545 posts
Posted April 12, 2013 - 04:07 AM
#8 bread320i OFFLINE
bread320i
  • 612 Thanks
  • 1,223 posts
Posted April 12, 2013 - 06:47 AM
You can also go to your local Napa if you know the model of your engine.
#9 eriklane OFFLINE
eriklane
  • 10 Thanks
  • 40 posts
Posted April 12, 2013 - 05:13 PM
Model 233431 Type 0024-01 Code 7905101
Its a new Briggs.  SO I go out to try and get the flywheel cover off. Hmm. An hour later, I realize it's going to require basically a full engine pull. The cowling cant come off until the drive shaft is disconnected and then the crank pulley has to come off.  Goodgod.
For a coil?  JOODAS.
Edited by eriklane, April 12, 2013 - 07:03 PM.
#10 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted April 13, 2013 - 04:27 AM
According to your engine numbers, you need Briggs & Stratton part #298968. You can get the coil from any Briggs & Stratton dealer or buy online.
Here's a link for an aftermarket coil:
http://www.ebay.com/...0387#vi-content
#11 eriklane OFFLINE
eriklane
  • 10 Thanks
  • 40 posts
Posted April 13, 2013 - 01:12 PM
Pulled the entire motor, took an hour. Not so bad once ya dive into it. Pulley/shroud off. Bingo-little wire on the coil was broken,and, the coil looks like it blew apart, I can see the inner windings...ordered one from Napa.  Success.
#12 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted April 13, 2013 - 10:26 PM
The late B10 was a 1966 model and was already at least two models obsolete by 1969. If the engine in it is the same size as the original than it is a 1963-64. model (early B10). Glad you got it going. Please post photos so we can tie down the model number.
Edited by skunkhome, April 13, 2013 - 10:32 PM.
