Ain't These Just So Pretty ?
9 replies to this topic
#1 NJKen OFFLINE
NJKen
  • 1362 Thanks
  • 1284 posts
Posted April 09, 2013 - 09:51 PM
Decided to pull these obnoxiously sticking out wheel weights off the HT-23 and put real Bolens wheel weights on. The extra weight of the plastic ones is great, but they stick out too far. Just last week I was pushing some brush in a wet area in the patch of woods near me and I got stuck, I slid into a tree, and the wheel weight wouldn't allow me to move, it was wedged up against a tree. Had to rig up a pulley and cable to pull back on an angle. The wife laughed her butt off when she had to come pull me out with her Explorer.
So the only sets I had, were red or filthy white. Wire wheeled the heck out of them, then primed with rusty metal primer. ImageUploadedByTapatalk1365562157.807150.jpg
That rotating stool worked great for priming and painting.
2nd coat of Gloss White sure made em pretty !! How could I have shown up at plow day with bum wheel weights ?
  • Texas Deere and Horse, hamman, blackjackjakexxix and 7 others have said thanks
#2 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted April 09, 2013 - 10:01 PM
They look Awesome Reminds me i need to bring my weight into school and sand blast them before schools out ...
And Plastic weight belong on Lawn tractors ONLY ... :P
#3 KennyP ONLINE
  • 53174 Thanks
  • 53311 posts
Posted April 10, 2013 - 04:06 AM
Hey now! Don't go messing with my plastic weights. There the only ones to be found in this part of the country. And I don't think an LT could handle 150 lb. of wheel weight!
#4 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 19106 Thanks
  • 11901 posts
Posted April 10, 2013 - 06:35 AM
Wonder how much lead shot it takes to fill a plastic weight???
#5 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted April 10, 2013 - 07:28 AM
I'll be sending you a crate of weights by freight, should be there Monday.  Send em back when you are done.
Ben W.
  • NJKen said thank you
#6 NJKen OFFLINE
NJKen
  • 1362 Thanks
  • 1284 posts
Posted April 10, 2013 - 07:44 AM
I'm guessing about 49.5lbs worth for a 50lb weight.
Those big plastic weights are 65lbs I think. And they have the Cub Cadet logo in the center cap. Anyone interested in those I'm taking offers. And I have another set of 12" that big and another set a bit lighter. 50lbs I think.
It only took about 30 mins tops to do each weight. Not counting drying time in between coats. Fast dry rusty metal primer was 15-20 mins and about an hour or so between the two finish coats.
When and if the sandblaster I ordered gets here, I'll do all the other cast iron weights too. So ship that crate full, I'll knock them out as well. : ) shipping will be a killer.
  • superaben said thank you
#7 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 10, 2013 - 08:45 AM
Those stick out pretty far!
I'm sure both you and the Bolens will be alot happier with the original weights installed :D
#8 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted April 10, 2013 - 10:05 AM
Good plan. I have caught things with the ends of my weight brackets on the 314. They stick out over 2" which is a bit too far. I think I'll cut them off to about 1" past the tire to prevent snagging stuff with them.
#9 SonnyT OFFLINE
SonnyT
    Deceased
  • 116 Thanks
  • 125 posts
Posted April 10, 2013 - 12:11 PM
good paint job! I will stick with my plastic ones for now since I am CHEAP!
#10 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
Posted April 10, 2013 - 10:05 PM
I stopped liking plastic weights after i nearly snapped a Axle (And my neck) when i cut a turn to close and caught a fence post with the weight i had to look around for a while to find cast weights but they are alot nicer IMO Weights Weight ... i suppose but on the tube frames you Don't use plastic weights as they affect the Differential Knob
