Kabota G2000
1 reply to this topic
#1 chrismatthewssr OFFLINE
chrismatthewssr
  • 1 posts
Posted April 08, 2013 - 07:07 PM
my gas pedal sticks, it is the hydrostatic push to go forward and push down with you heel to go backwards what can i do to free it up, the mower is a Kubuto G2000
#2 Cvans ONLINE
  • 7,459 Thanks
  • 6,468 posts
Posted April 08, 2013 - 07:51 PM
Your going to have to follow the linkage from the pedal to the hydro. If it were me I would disconnect The linkage from the hydro and see if you can move the pedal. If you can that will tell you that your problem is not in the linkage. If you can't move it you will have to start lubricating all the joints in the linkage and hopefully that will loosen things up.
Good luck
