110 Help Needed
8 replies to this topic
#1 wku88 OFFLINE
wku88
  • 22 Thanks
  • 35 posts
Posted April 07, 2013 - 05:44 PM
Trying to resurrect a 110 for actual work, i.e. NOT a restoration/parade queen. Having a devil of a time figuring out the drive system.  First question, is the variator spring larger, or smaller than the secondary belt tensioner spring? (my variator spring was missing)
Next, anyone have part numbers for the primary and secondary belts? Any leads on best places to order these, or is it an in stock deal at the JD store?
I do have the JD manual, and so far it has been helpful, but I am sure someone with experience can do a better job of explaining this system to me.
#2 KennyP ONLINE
  • 38,274 Thanks
  • 45,881 posts
Posted April 07, 2013 - 05:46 PM
Welcome to the forum! I'm no help here, but others will be along shortly!
  • wku88 said thank you
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted April 07, 2013 - 06:02 PM
:welcome: :wewantpics:
#4 wku88 OFFLINE
wku88
  • 22 Thanks
  • 35 posts
Posted April 07, 2013 - 06:22 PM
Here ya go...
  • CRFarnsworth said thank you
#5 wku88 OFFLINE
wku88
  • 22 Thanks
  • 35 posts
Posted April 07, 2013 - 06:23 PM
Hood is busted up, but complete, grille, and upper light panel is MIA. Probably bend up a piece of steel or just pop rivet a mesh screen  to keep the big stuff off the motor.
#6 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted April 07, 2013 - 08:32 PM
part number is M45274 EXTENSION SPRING
I checked my local JD dealer and his price is $25.29
look around for a used one in your area, somebody might have one cheaper
#7 wku88 OFFLINE
wku88
  • 22 Thanks
  • 35 posts
Posted April 07, 2013 - 09:09 PM
Couple on Ebay now, but which is which? Is the variator spring the big one, or is the tensioner spring for the secondary belt the big one?
#8 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted April 07, 2013 - 09:17 PM
Can't help on the spring, but the belts you will want to get at the JD dealer. JD uses a special angle belt that you can't buy from the local supply house. Good Luck..
#9 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted April 07, 2013 - 11:37 PM
yes the larger diameter spring is for the variator $(KGrHqR,!igE5hBiV4WcBOdMbpzJm!~~_1.JPG
I check e-bay and I did not see the variator spring there.
I can not sure the 110 and the 200 series are the same - will have to check mine
I check JD parts and both the 100 flat fence series and 200 series use the same part M45274
the round fence 100s use a different one
but see if you have somebody close to see on craigslist that sell parts from old GT that they take apart and sell
I have s few around here that sell on craigslist
you can make a post in the wanted section here on gardentractortalk
good luck - you will find one
Edited by lyall, April 07, 2013 - 11:49 PM.
