My Creation...
22 replies to this topic
#1 Jordan9682 OFFLINE
Jordan9682
  • 71 Thanks
  • 137 posts
Posted April 07, 2013 - 10:25 AM
Here is a garden seeder i built. its very simple, push it along and drop your seeds down the pipe :) I'm thinking i will see if i could make a simple little meter for it, to make things easier :D
I plan to seed my corn with it, much better than a hoe and a little sack of seeds
  • HDWildBill, jd.rasentrac and Dieselcubmike have said thanks
#2 KC9KAS ONLINE
KC9KAS
  • 5,466 Thanks
  • 4,722 posts
Posted April 07, 2013 - 11:19 AM
Neat, but if you put the pedals back on, you won't have to walk!!
Edited by KC9KAS, April 07, 2013 - 11:20 AM.
  • LilysDad and Jordan9682 have said thanks
#3 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted April 07, 2013 - 11:51 AM
I bet that little boy is crying his eye out looking for his bicycle.
Dick
  • twostep said thank you
#4 Jordan9682 OFFLINE
Jordan9682
  • 71 Thanks
  • 137 posts
Posted April 07, 2013 - 11:53 AM
Most of it is still intact... Just the handle bars and front tire is missing...
Edited by Jordan9682, April 07, 2013 - 11:53 AM.
#5 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted April 07, 2013 - 11:55 AM
Looks very nice :thumbs:
  • Jordan9682 said thank you
#6 Jordan9682 OFFLINE
Jordan9682
  • 71 Thanks
  • 137 posts
Posted April 07, 2013 - 12:54 PM
Still needs paint...
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,807 Thanks
  • 4,302 posts
Posted April 07, 2013 - 01:54 PM
Yep, can be used for many things... How will you separate the seed? A vid will be interesting :thumbs:
#8 Jordan9682 OFFLINE
Jordan9682
  • 71 Thanks
  • 137 posts
Posted April 07, 2013 - 01:57 PM
What do you mean? I will drop seeds in, and hope I'm being accurate about it
  • twostep and jd.rasentrac have said thanks
#9 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,120 Thanks
  • 10,188 posts
Posted April 07, 2013 - 04:49 PM
That'll save your back! How about a seed hopper and a trigger?
#10 Jordan9682 OFFLINE
Jordan9682
  • 71 Thanks
  • 137 posts
Posted April 07, 2013 - 05:55 PM
Currently working on one, it'll be an agitator that spins and seed will drop down.
I'll take a pic of it when its done
#11 Jordan9682 OFFLINE
Jordan9682
  • 71 Thanks
  • 137 posts
Posted April 07, 2013 - 09:27 PM
Okay, just got done!
Here it is,
I dont have it on yet
As you can see its only about 4" wide, and has a small agitator in it, and a tiny hopper above it. And I will run it by using the crank.
The holes in the bottom were burnt through with a welder, not pretty but they won't be seen anyway.
Everything except the agitator and crank are 1/4" thick steel
Edited by Jordan9682, April 07, 2013 - 09:29 PM.
  • jd.rasentrac said thank you
#12 Jordan9682 OFFLINE
Jordan9682
  • 71 Thanks
  • 137 posts
Posted April 07, 2013 - 10:00 PM
Easier to turn a crank than to drop seeds into the tube? Yeah, I think so
#13 KennyP ONLINE
  • 40,925 Thanks
  • 47,117 posts
Posted April 08, 2013 - 05:00 AM
Now that's different. How far apart are you wanting the seeds?
#14 Jordan9682 OFFLINE
Jordan9682
  • 71 Thanks
  • 137 posts
Posted April 08, 2013 - 08:31 AM
I'm thinking fairly close, 1- 2" (my expirience with growing corn is that it is very poor seed,but this year I'm using different seed from a different company. So that could change)
But as far as plants go, I'm thinking 4" apart on 24" row spacing
#15 HDWildBill OFFLINE
  • 8,984 Thanks
Posted April 08, 2013 - 10:21 AM
Connect your crank to the wheel and let the wheel do the work for you.  Looks like you will have a good tool for planting.
