Complete Restored T70
73 replies to this topic
#1 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 07, 2013 - 07:59 AM
Got this t70 from a friend, was painted red. I took it apart and started blasting every part.Removed diff and replaced bearings and seals.Axel bearings, relined brake shoes. turned drums, When sand blasting the frame i found that the bottom was all rotted out.The tubes had filled with water over the years and there was no way to repair then.So ended up making new tubes.They built them with BLACK PIPE . So off to hard ware store to get a 8 foot pipe. Set up in my bridgeport and drilled all the holes. set up on welding bench. blasted and painted.1023101614_zps195ef711.jpgpanzer005.jpgpanzer006.jpg
  • Gtractor, CRFarnsworth, Clint and 5 others have said thanks
#2 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted April 07, 2013 - 08:01 AM
Nice job!
#3 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 07, 2013 - 08:03 AM
That sure does sound like a total rebuild. Frame and all. That's a lot of work.
Looking forward to seeing the final outcome.
Oh yeah, Welcome to GTT. :wave:
#4 Newpaws493 OFFLINE
Newpaws493
  • 1,368 Thanks
  • 1,811 posts
Posted April 07, 2013 - 08:37 AM
  :welcometogttalk:  LookinGood ! won't mind seeing how this turns out either... :watch_over_fence:
#5 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 07, 2013 - 08:38 AM
Heres a few pictures of the frame.2012-11-20075740_zps56fda0c4.jpg2012-11-20075729_zps99b50e39.jpg also made new front axle pivot.Made new front spindles, replace steering gears with NOS, also rebuilt the old briggs and stratton engine.
  • CRFarnsworth, Clint, Newpaws493 and 3 others have said thanks
#6 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 07, 2013 - 08:44 AM
1217101809_zps31fd0060.jpg I also picked up this NOS deck for it. never been used.2012-12-14165522_zps3687b860.jpg
  • Clint, LilysDad, Brando and 1 other said thanks
#7 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted April 07, 2013 - 08:51 AM
Wow, that is awesome looking!
#8 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 07, 2013 - 08:58 AM
Nice work.
That's a real score on the NOS deck. Lucky you.
#9 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 07, 2013 - 08:59 AM
Thanks guys, heres a few more. going together fast.124_zpsec0e7a30.jpg.119_zps0cf76161.jpg
  • IamSherwood, CRFarnsworth, Clint and 3 others have said thanks
#10 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 07, 2013 - 09:17 AM
The hard part about restoring this machining the markings off the bolts bead blasting prime and paint every nut and bolt and parts. Im using A fleet paint called nason. 2 part paint goes on very nice.Will have this out in know time. I also had new decals made up. even for the engine plate.Panzer built all these tractors with fine treaded bolts. I had my decal guy put all the right numbers one it.
  • New.Canadian.DB.Owner and LilysDad have said thanks
#11 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
  • Clint, Newpaws493, LilysDad and 2 others have said thanks
#12 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 07, 2013 - 09:19 AM
  • IamSherwood, boyscout862, LilysDad and 1 other said thanks
#13 Newpaws493 OFFLINE
Newpaws493
  • 1,368 Thanks
  • 1,811 posts
Posted April 07, 2013 - 09:25 AM
Quality job bottom to top, Thanks for sharing this! :rocker2:
#14 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 07, 2013 - 09:31 AM
Yep, beautifull job there. Don't forget to put some pictures of it in the
Gallery, when she's done.
#15 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted April 07, 2013 - 09:33 AM
Guys i also put up one of my pullers for tractor of the month , Wheel horse puller Check it out too. Thanks for all the nice words.
Edited by Chris11, April 07, 2013 - 10:36 AM.
