Wiring Question
8 replies to this topic
#1 lyall OFFLINE
lyall
  • 2,015 Thanks
  • 1,524 posts
Posted April 06, 2013 - 09:02 PM
on the JD 210 I got from Craigslist
I was checking it over today and cleaning it up
why would somebody ran a wire from the positive side of the battery to a troggle switch then to the positive side of the coil?
I check the switch with a multi meter and it checks okay.
also check the rest of the wiring from any shorts - so far so good
had fun cleaning the motor - a mouse make a nest behind the flywheel housing
lots of little nuts and some walnuts it there
he told me that  he rebuild the motor and it rum great, but he had problems with the drive belts
so out came the variator and check it over. a little work on it and now it is spins free.
will open up the transaxle this week and check it over
had to get a battery for it - went to a junk yard and brought a battery from a 2012 Ford for $35
got a year warranty this it.
  • larryd said thank you
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted April 06, 2013 - 09:09 PM
The only reason someone would put a toggle hooked like that  would be if they were not getting 12 volts at the coil with the key on. So possibly it has or had a bad switch or bad wire or connection in that circuit.
  • lyall and larryd have said thanks
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,096 Thanks
  • 4,878 posts
Posted April 06, 2013 - 09:15 PM
I bet after it runs a while it quits and the wire is to bypass the switch to make sure the coil is getting power.  Dad has a 318 that quits often.  After changing the coil MANY times which is quite an ordeal because of the position of the engine, he just takes a break and lets it cool off for a while and then goes back to mow later.
#4 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted April 07, 2013 - 12:09 PM
"Secret Hidden Anti-Start Switch"?
  • lyall said thank you
#5 lyall OFFLINE
lyall
  • 2,015 Thanks
  • 1,524 posts
Posted April 07, 2013 - 12:57 PM
but it is not hidden on the dash
#6 Trav1s OFFLINE
Trav1s
  • 3,160 Thanks
  • 4,274 posts
Posted April 07, 2013 - 01:08 PM
Hidden in plain sight with a label that says "laser"
#7 HDWildBill OFFLINE
  • 8,975 Thanks
Posted April 07, 2013 - 06:11 PM
I have a zero turn in the shop now that someone put a toggle switch and a push button because the ignition switch and PTO switch went bad.   I know it took me less time to get the switches and replace them both then it did for who ever to drill the two holes and then rewire them.  It bets me why people don't do things the right way to begin with.
#8 wku88 OFFLINE
wku88
  • 22 Thanks
  • 35 posts
Posted April 07, 2013 - 09:23 PM
I am going to do the same with my 110. The new switch I got from Lowes today will show 12v when the switch is on, but cuts power when cranking. The only leg of the switch available is the "L" leg, which I assume means lights. So, it cuts power to the lights when cranking. Thus, I'll have to put a DPST toggle switch in so I get power to the coil while cranking.
Hope this helps...
#9 lyall OFFLINE
lyall
  • 2,015 Thanks
  • 1,524 posts
Posted April 14, 2013 - 07:20 PM
I was working on the 210 this weekend checking the wiring over making sure the wiring is good
found out why they put it on.
the connector next the the motor had a bad connection to the coil
the two connection would not connect
took the connection apart and the female connection was bad
tried a male connection it in , loose. so I crimped it tight and checked it the meter
good connection now
put it back together and check the other wiring - all looked and tested good on the meter
put the battery in and it fired up
it run good for sitting for around 10 years
smokes for a while has good compression
it might take a while for the rings to free up
