Lgt 195 Verses Lgt 165
17 replies to this topic
#1 Rock farmer ONLINE
Rock farmer
  • 1,240 Thanks
  • 1,247 posts
Posted April 05, 2013 - 08:50 PM
How do these two compare? Is the LGT 195 a bigger machine? Or, just added options? I can fit an LGT 165 into the back of a full size 8 foot bed GMC. Would a LGT 195 fit as well? The 195 is heavier, about 200 lbs? I don't know why it would weight 200 lbs more.
Anybody know?
Thanks,
Joe
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,273 Thanks
  • 10,114 posts
Posted April 05, 2013 - 09:20 PM
195 is much bigger.
  • Rock farmer said thank you
#3 Buck OFFLINE
Buck
  • 36 Thanks
  • 116 posts
Posted April 05, 2013 - 09:22 PM
Joe, The 195 many different parts. I know this because I am searching for a steering assembly for my gt 14 on ebay. The 195 shows up and the parts are different. The fender pan is different as well as they have lights up near the seat. I think the motor was a kohler 18 hp. All this may add up to the added weight. Also these tractors seem rare. You may find more info on Tractor data.com I have not looked it up. As for the 165 fitting in a pickup, it will. I think the wheel width is around 38".  It is under 8' long. The only thing would be a mower deck depending on the width if it would fit between the wheel wells. I had a Craftsmen with a 42" deck and tripple bagger that I borrowed and had it in my Ram with a 6' bed. I could not close the tailgate but fit otherwise. It was about the same width as the 165 but not as heavy.
Hope this helps,
Buck
Sorry, I had just read your post again and I thought you were asking about the 165 fitting in your truck, not the 195. You going to New York to get that 195?
Edited by Buck, April 05, 2013 - 09:26 PM.
#4 Rock farmer ONLINE
Rock farmer
  • 1,240 Thanks
  • 1,247 posts
Posted April 05, 2013 - 10:35 PM
"Sorry, I had just read your post again and I thought you were asking about the 165 fitting in your truck, not the 195. You going to New York to get that 195?"
I'm thinking about it. I sure would like to have a three point hitch and power steering. But the logistics have me wondering if its worth it?
Thanks!
Joe
#5 skyrydr2 ONLINE
  • 3,908 Thanks
  • 3,411 posts
Posted April 06, 2013 - 03:42 AM
The 195 is a total different animal, and very hard to find parts and attachment for. It was only made for a year or two at best and didn't sell that well in most parts. From what a dealer friend told me ( he grew up selling and servicing Ford tractors) that the 195 s had a ton of issues from the power steering to engine overheating. So they discontinued them? Whether this was true I can not confirm, but I will say this, I would like one !! As it would work real nice with a diesel under the bonnet.
#6 KennyP ONLINE
  • 40,187 Thanks
  • 46,794 posts
Posted April 06, 2013 - 04:06 AM
Here's the dimensions:
Wheelbase .  . . . 56"
Length Overall . . 84"
Width Overall . . . 49" (without mower)
Height Overall  . . 46"
Ground Clearance . 10"
Weight . . . . . . . . 1030#
Just bigger all over. IF you find one with attachments, better grab it. Rear PTO is hard to find. Here's the operators manual. If you have the Parts Manual downloaded, you will see in there the 195 is separate.
#7 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted April 06, 2013 - 06:32 AM
Pretty rare up here. In fact I've never seen one even though the 165/145 are quite common. Looks like Fords answer to the large "Super"GT's like the big CC's and the JD400series.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 06, 2013 - 09:15 AM
From what I have read the 195 was aimed at being an entry into the compact tractor market.
Much like the AC 620 & 720, But abot the same time the japanese tractors were discovered.
Thats when ford started marketing the Shibara tractors
#9 TomLGT195 OFFLINE
TomLGT195
  • 4,016 Thanks
  • 2,884 posts
Posted April 08, 2013 - 04:52 PM
I just bought a 195 and already have a 145 and they are two very different tractors in several ways. I guess it depends on what your gonna do with it. My 195 is slated for a loader and the 145 i use for the 4-way plow and has a better turning radius. the 3pt on the 195 is a plus too.
good luck on your decision
the 195 would be a tight squeeze in a truck, you probably would do better with a trailer, easier to load that for sure.
#10 Rock farmer ONLINE
Rock farmer
  • 1,240 Thanks
  • 1,247 posts
Posted April 16, 2013 - 05:40 PM
So,
It turns out that it will fit in the back of the truck rather neatly. It does completely fill the truck though! Truck rode fine. But, you knew you had 1,000 lbs back there!
Joe
#11 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted April 24, 2013 - 08:17 AM
Well just so all know,,,, I wouldn't take anything for my 195 thats for sure,,,, Been a great tractor since I have own it an been makein things for it that I may need to get diff job's done,, Had lil prob's with the belt popin off of the deck when mowing the grass but come to find out that the belt that was on it was about 3 inches to big so prob solve an still kicking,,,lol
#12 KennyP ONLINE
  • 40,187 Thanks
  • 46,794 posts
Posted April 24, 2013 - 08:32 AM
Russ, glad to hear it's still going strong for you. Too bad they didn't make a few more of them!
  • Russ said thank you
#13 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted April 24, 2013 - 08:56 AM
Yea I hear that Kenny,,, I not been able to repaint mine yet but still workin on that part,,lol
#14 RedJake OFFLINE
RedJake
  • 23 Thanks
  • 23 posts
Posted April 29, 2013 - 01:48 PM
As far as loading a 195 onto a truck bed I imagine that would be very difficult. I had to rent a U-Haul enclosed 6 x 12 trailer to bring my Jacobsen (same as 195) home. This tractor, as mentioned, weighs over 1,000 lbs and mine came with implements. You would need an awfully large bed to load this puppy.
#15 Rock farmer ONLINE
Rock farmer
  • 1,240 Thanks
  • 1,247 posts
Posted April 29, 2013 - 04:52 PM
Well actually, I drove it to the top of a hill. And we attached to my nephew's jeep with a long line because the brakes on the tractor weren't working and just rolled it in!
I have a 2005 GMC half ton. I was able to put the tail gate up for the ride home (100 miles). I had no attachments to load. That would have been another trip.
Joe
