442 ?
9 replies to this topic
#1 Jake OFFLINE
Jake
  • 225 Thanks
  • 127 posts
Posted April 03, 2013 - 04:14 PM
Just pick up a 442 with manual lift My ? Is will the T C Valve out of one with hydraulic lift bolt in ( lines and such) I will keep the manual lift and just use the new hydraulic ports for a 3 point hitch thanks Jake
#2 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted April 03, 2013 - 07:27 PM
I can't answer your question, but somebody will be able to help you out! The best I can do is bump it so one of the hydraulic gurus will see this!
#3 KC9KAS OFFLINE
KC9KAS
  • 4,969 Thanks
  • 4,398 posts
Posted April 03, 2013 - 07:29 PM
When you said 442, here is what I was thinking!
$T2eC16hHJGsFFMlsmVBGBRV3IZRgQg~~60_3.JP
  • Dieselcubmike and Tomwendt have said thanks
#4 backwoods ONLINE
backwoods
  • 2,381 Thanks
  • 2,670 posts
Posted April 03, 2013 - 07:30 PM
no clue pics might help for those who are knowledgable in this area
#5 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted April 03, 2013 - 08:48 PM
What will you be using for a hydraulic pump? Welcome to the forum BTW. I have a '71 444 and love it.
-Matthew
#6 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Hey Ryan, Not to hijack this post but I just noticed that you changed your avitar to show case that york rake. Looks great.
  • Ryan313 said thank you
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,170 Thanks
  • 5,768 posts
Posted April 04, 2013 - 01:43 AM
:welcometogttalk: :wewantpics:
#8 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted April 06, 2013 - 07:57 PM
I just saw your thread and I also have a 442, but I'll have to check for you . I suspect you should have no problem with lines etc. I'll check those against my 446--Both are sunsets--What is your Pin # on the 442?
#9 Jake OFFLINE
Jake
  • 225 Thanks
  • 127 posts
Posted April 07, 2013 - 05:35 PM
# is 9633748 cane you tell what year this is thanks Jake
#10 Cat385B ONLINE
    Therapy CAT
  • 12,345 Thanks
  • 9,203 posts
Posted April 07, 2013 - 05:54 PM
1970 or 1971 model. Does it have the snap-fast attachment pins on the front? If so, its a 71. If not, it's a 70.
