Whats A 782 Worth?
11 replies to this topic
#1 56series OFFLINE
56series
  • 31 Thanks
  • 31 posts
Posted April 03, 2013 - 04:12 PM
Guy up the road from me has a 782 gas, that does not run at this time. Says it got water in the gas and shut off, and has been sitting there (in the same spot) for 3 to 4 years. I asked years ago about selling the tractor, but was told no. He just called and asked if I was interested in it, casue he is looking for money to help with pay for a new planter he is looking at. Has a deck with it, and I don't know what all else. It did at one time have the factory hub caps for it too, but they are missing.
Wish I had pictures of it for uyou guys. Sorry!
Thanks
Jason
#2 boyscout862 OFFLINE
  • 13,441 Thanks
  • 9,391 posts
Posted April 03, 2013 - 06:04 PM
Take some pics and check if the engine is siezed. Good Luck, Rick
  • 56series said thank you
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,889 Thanks
  • 10,052 posts
Posted April 03, 2013 - 07:48 PM
Isn't this the one with the bad engine design? Type I vs Type II?
I would go on the assumption that the engine is bad and price accordingly.
Edited by LilysDad, April 03, 2013 - 07:49 PM.
#4 IHCubGuy OFFLINE
IHCubGuy
  • 1,592 Thanks
  • 1,632 posts
Posted April 03, 2013 - 10:06 PM
A few factors here.  Is the engine fast?  As pointed out above what model engine is in it, Series 1 or Series 2.   Series 1 isnt a deal killer but would be worth less.  Series 1 will not have an oil filter, series 2 should as they are pressure lube where seies 1 are not.  Is it an IH built unit or a MTD built unit?  How many hours are on it?
Without knowing any specifics I would say between 400 and 1200 to start.
#5 twostep ONLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,539 posts
Posted April 03, 2013 - 10:35 PM
hmm... was the oil filter was an option/add-on???
http://gardentractor...-and-2-engines/
http://www.weekendfr...s/335/1323.html
To the OP: it REALLY depends on the condition of the GT. The engine doesn't run so it us valued at ZERO unless it cranks over fine and has good compression... I gave $500 for my 682 running, mowing, zero tin rust and over all in decent condition. But I've seen 782's in 25% as good of condition for the same price. If you look at it from parts perspective, the rearend could be worth $100 to $200, Deck lift valve and cylinder is another $150. Deck (with good spindles) could be worth $100 to $200. Tires are likely shot but you can judge and you know that re-tiring a GT is $150-$200 minimum.
Edited by twostep, April 03, 2013 - 10:37 PM.
#6 56series OFFLINE
56series
  • 31 Thanks
  • 31 posts
Posted April 03, 2013 - 10:36 PM
There is a guy with a 782 on the tractors for sale board that is asking $800 top, but his sounds like a nice tractor with two sets of tires, blade, deck. I don't know which series of engine it has in it. To be honest I didn't even know there were two series. The later models of tractors I'm not to familer with! I will get some info. and let you gents know. And :camera:too!
Thanks
Jason
#7 56series OFFLINE
56series
  • 31 Thanks
  • 31 posts
Posted April 03, 2013 - 10:46 PM
Thanks for the pictures, I will check to see which engine is in it. Your 682 is a nice machine!
Thanks again for the info.
Jason
  • twostep said thank you
#8 twostep ONLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,539 posts
Posted April 03, 2013 - 10:59 PM
Ever since I've gotten to these machines I've read how the series II is superior... but I've also read that a series I will work just as hard IF it it ran on flatter ground. From my research their bane is hilly ground where the engine just can't lubricate itself enough.
#9 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted April 04, 2013 - 05:08 AM
The series 2 engine on the JD 317's did not have an oil filter. There is a sticky here on how to tell the 2 apart. http://gardentractor...-and-2-engines/
#10 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,889 Thanks
  • 10,052 posts
Posted April 04, 2013 - 07:05 AM
From Tractor Data:
  Engine Detail: During production, the Cub Cadet 782 switched from a Kohler KT-17 Series I motor to a KT-17 Series II motor. The Series II motor offered full-pressure oil lubrication. The Series I a limited pressure lubrication system. The Series II can be identified by a decal on the cover of the air filter or an engine specification number that is 24300 or higher. Engine Type: Kohler KT-17   gasoline   2-cylinder   air-cooled Opposed Twin Displacement: 691 cc [42.18ci ] Bore/Stroke: 3.125x2.75 inches [79 x 70 mm] Power (gross): 17 hp [12.7 kW] Air cleaner: dry Starter volts: 12 Oil capacity: 1.5 qts [1.4 L]
Enough Type Is were replaced w/ Type IIs that it is getting hard to find a used T II for a decent price.
#11 HALFSCALE OFFLINE
HALFSCALE
  • 505 Thanks
  • 533 posts
Posted April 04, 2013 - 08:29 AM
I bought my daughters' 782  for 300 at a sale a few years ago and then had to put a couple a hundred in to get it running, coil,starter, plugs, points, tire ,battery , it really adds up in a hurry. But there a great tractor. If it has the black front axle and rear, then it was built buy Mtd right before the buy out of cub.
  • LilysDad and 56series have said thanks
#12 twostep ONLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,539 posts
Posted April 04, 2013 - 10:43 AM
This got me to doing some research when i went out to look at mine and I couldn't find the oil filter provisions... turns out not all of the series II's had this feature: http://onlycubcadets...hread.php?t=319
