Packer/cultipacker Idea!
5 replies to this topic
#1 Jordan9682 OFFLINE
Jordan9682
  • 71 Thanks
  • 137 posts
Posted April 03, 2013 - 12:38 PM
I have an idea for a packer/cultipacker(not sure which it would be), so here it is. Take some small tires like these
And put them on an axle, all side by side (maybe about 1/2" spacer between each?) and put a hitch on. (This probably isn't an original idea)
The hitch would need a place to set a cinder block or two for some weight.
Think that would be a good project? Or waste of time?
#2 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted April 03, 2013 - 03:14 PM
I don't think you could get enough weight to do you much good. All those wheels would increase the bearing surface so there would be little pounds per square inch.  I had a job in the factory where I dip painted 1000 40 lb cast cultipacker wheels per day.
Lifting them off a rack hanging them on the dip paint line and then restacking them amounted to 80,000 pounds lifted per day.
#3 KennyP ONLINE
  • 37,543 Thanks
  • 45,533 posts
Posted April 03, 2013 - 03:15 PM
That could work. Depending how far the hubs protrude (or not) would set your spacer. I'd keep them pretty close together, but trial and error would figure things out.
#4 Jordan9682 OFFLINE
Jordan9682
  • 71 Thanks
  • 137 posts
Posted April 03, 2013 - 03:39 PM
For weight i could make the hitch fairly strong and put a small water tank on
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted April 04, 2013 - 02:10 AM
The weight would probably work best over the wheels.
#6 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted April 04, 2013 - 05:42 AM
Would a single gang disk set stright set the seeds buryed and then just drive over it  with just the tractor to push the soil flat ?
