Briggs Carb Kit - Which Bowl Gasket Do I Use?
1 reply to this topic
#1 motobreeder OFFLINE
motobreeder
  • 425 Thanks
  • 611 posts
Posted April 02, 2013 - 09:45 PM
Hi,
Is this something I should know by now?
When I look at the gasket kits for the Briggs flo-jet carburetors, there are usually two bowl gaskets.  They look the same except for the size and location of the holes.  Which gasket do I use?
In this case "same as what was there" doesn't work.  It was home-made and had 3 holes.
Looking at the following kit:http://www.mfgsupply...ts/22-1416.html
(hopefully the correct kit for a model 19 briggs).
aTdHvAaNnKcSe
#2 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted April 03, 2013 - 04:38 AM
The gasket for a model 19 should look like this:
http://www.mfgsupply...result/?q=27034
Here's another aftermarket replacement for the Briggs #394693 kit:
http://www.jackssmal...2397/2672397/pd
  • motobreeder and boyscout862 have said thanks
