Cub Original Project
19 replies to this topic
#16 Dane in PA OFFLINE
Dane in PA
    Dane in PA
  • 531 Thanks
  • 601 posts
Posted April 19, 2013 - 08:20 AM
I got it running last night.  It runs well, but smokes like crazy.  I will be picking up another motor to drop into it sometime soon, so I will have one for parts.  It shifts through all gears and drives well.  Clutch works well, too.
  • DB1 said thank you
#17 Dane in PA OFFLINE
Dane in PA
    Dane in PA
  • 531 Thanks
  • 601 posts
Posted May 07, 2013 - 08:52 AM
I know I haven't posted a lot as of late on this forum about this project, but here is a little update and some pictures:
I have it running and driving, I got a replacement engine (though I can't get the PTO off...) and got it cleaned up nice.  It runs great with no smoke at all, though I had to tear down both engines to make one good one, as the new one had a badly cracked head, and needed the yellow tins.  She drives well, though needs some clutch work.  Will spin the tires in 1st and 2nd, but won't in 3rd.  Don't know if its the belt, clutch, or both.  Does anyone have access to a wiring diagram?  Mine's wiring was trash and to run it I'm using a NEG. lead the the frame and a POS. lead to the coil.  Thanks in advance.
  • DB1 and twostep have said thanks
#18 Dane in PA OFFLINE
Dane in PA
    Dane in PA
  • 531 Thanks
  • 601 posts
Posted May 07, 2013 - 08:58 AM
More pictures:  Last group didn't load all.
#19 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,028 Thanks
  • 1,455 posts
Posted May 07, 2013 - 11:13 AM
Looking great!!! Here is a diagram. The wiring should be pretty simple on those. Not sure what you mean by running negative to the frame and positive to the coil. It should have the points and condensor hooked to the negative side of the coil and 12 volts coming to the positive side.
  • DB1 and Dane in PA have said thanks
#20 Dane in PA OFFLINE
Dane in PA
    Dane in PA
  • 531 Thanks
  • 601 posts
Posted May 07, 2013 - 12:44 PM
Thanks for the diagram!  I meant that I have the battery leads connected to the frame, and the coil.
  • LTD and DB1 have said thanks
