Oil Change
15 replies to this topic
#1 WHdbJD OFFLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted April 02, 2013 - 02:25 PM
My thread about overfilling the Kohler engine, led me to some other questions;
Do you have a particular brand of oil you prefer?
Viscosity?  Detergent or non detergent?
I use straight 30 weight in the older engines that only run in the summer months.
10W30 is what I use in the JD that is run summer and winter.
TurfGuard from JD dealer
Edited by WHdbJD, April 02, 2013 - 02:26 PM.
#2 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted April 02, 2013 - 02:51 PM
I always use SAE 30, since that's primarily what they were made to handle.
I'm sure there's another thread on this: we all like arguing oil.
Ben W.
  • WHdbJD and twostep have said thanks
#3 WHdbJD OFFLINE
WHdbJD
  • 686 Thanks
  • 516 posts
Posted April 02, 2013 - 03:01 PM
Oops,you are probably right, I should have done a search for this topic...
#4 KC9KAS ONLINE
KC9KAS
  • 5,388 Thanks
  • 4,692 posts
Posted April 02, 2013 - 03:45 PM
Man you opened up a "can of worms" now! :deadhorse:
  • WHdbJD and backwoods have said thanks
#5 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted April 02, 2013 - 04:14 PM
I never change oil, just top them off. :D :bigrofl:
Brands,who cares, on small engines I just get whats on sale, more important to change it often.
That's why I can't do expensive oil, I would try to get to much out of it. On some things like a log splitter I change it after each use, as it may sit for a few months until it gets used again. Depending on season, 30wt or 10-30wt.
P.S. The Cases only get Shell 15-40, in the hydraulics. :thumbs:
#6 crittersf1 ONLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted April 03, 2013 - 01:11 AM
I use a good name brand like "Super Tech". :bigrofl: :bigrofl: :bigrofl: :bigrofl: :bigrofl:
  • twostep said thank you
#7 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 03, 2013 - 05:40 PM
i use what ever i used in the cars in my gt's as well 10w30 im not going into the which brand is better fued so ill leave it alone for now lol
#8 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 03, 2013 - 05:59 PM
Black Gummy Bears work just as well as any oil.
This is what they look like after they come out
at the end of the season. :D
#9 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 03, 2013 - 06:32 PM
thats crude oil for sure lol
#10 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted April 04, 2013 - 08:05 AM
i run 30w in all my flat head stuff. OHV get 10w30
#11 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 04, 2013 - 08:23 AM
is sae 30w no detergent??
#12 crittersf1 ONLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted April 04, 2013 - 08:29 AM
It will say "non-detergent" on it.
#13 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 04, 2013 - 08:52 AM
ok thanks whts the difference between detergent and non? never been real clear on that
#14 Canawler ONLINE
Canawler
  • 1,948 Thanks
  • 1,803 posts
Posted April 04, 2013 - 10:18 AM
Not to sound like a jerk... one has detergents & one doesn't. :smilewink:
Straight 30 weight is available both ways. The logic behind using non-detergent oils is that most small engines commonly don't have oil filters. Normal detergent type oils also contain dispersants to suspend contaminants in the oil and then they would be trapped in an oil filter. Without the filter, the contaminants get circulated throughout the engine and could damage the rings and bearings. Non-detergent oils tend not to clean as well and don't get contaminants suspended as long. They tend to settle to the oil pan. At least that's the theory.
Personally, I prefer the cleaning action of a modern oil. Its just a bit more important to change the oil more often if the engine doesn't have a filter. Not because the oil is worn out, but to get rid of the contaminants.
I would definitely use a detergent oil in engines with pressurized, filtered lube systems.
Edited by Canawler, April 04, 2013 - 12:03 PM.
  • backwoods and twostep have said thanks
#15 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted April 05, 2013 - 08:23 AM
thanks for clearing it up for me over ther years ive never under stood why one was used  for this and the other for something else. i class last semester the teacher went over the different weights in depth which i thought was helpful he just never cover the detergent vs non topic.
