Engine Mounts Jd314 K321
9 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 01, 2013 - 08:36 PM
Does anyone know how much higher the center of the mount is over the outside edge ? Mine are about 1/4" to 3/8" . Do I need new mounts ?
larryd
Edited by larryd, April 01, 2013 - 08:37 PM.
#2 jd.rasentrac ONLINE
jd.rasentrac
  • 4,719 Thanks
  • 4,220 posts
Posted April 02, 2013 - 02:54 AM
Hi Larry, sorry, but I don't understand what you want. Can you show it with a photo - I'm a little perplex :hitting_self_roller:
Edited by jd.rasentrac, April 02, 2013 - 02:55 AM.
  • larryd said thank you
#3 JDBrian OFFLINE
  • 9,599 Thanks
Posted April 02, 2013 - 05:16 AM
Larry. The rear mounts are a standard plate mount. There are second source suppliers on ebay. The total mount height is .62" . I can't remember how far they stick up above the plate. Lord is the company that made the mounts for JD. McMaster Carr sells mounts that are the same size. The problem is making sure you get the correct spring rate in the mount. The front mounts are not available from a second source. I tried and would have needed to buy 400 to get them. You can find used ones on ebay. The mounts crack with age and the engine starts to vibrate a lot. A close inspection( top and bottom) should let you know whats up. Sometimes oil causes the rubber to swell and turn soft as well.
  If you want more info. let me know and I'll see if I can dig up the measurements.
#4 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 9,958 Thanks
  • 5,575 posts
Posted April 02, 2013 - 05:29 AM
On my old 314 the metal cracked so I welded the thing up with a hefty bead..  They withstand a lot of stress as the tractor is shaft driven and has a rock solid hydro!  BTW they are a bear to install on the engine..  Not a lot of room to work.. :wallbanging:  You may utter a few cuss words!!
Edited by WNYTractorTinkerer, April 02, 2013 - 05:31 AM.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,195 Thanks
  • 5,795 posts
Posted April 02, 2013 - 05:52 AM
You might even come up with some new words.
#6 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 02, 2013 - 08:01 AM
From what you are saying I believe mine are ok . They aren't cracked or oil soaked As for height I was talking about the height of the t op of the bushing the bolt goes through to the outside diameter of the mount I can't take pictures now , sorry
Thanks
larryd
#7 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted April 02, 2013 - 08:08 AM
Thanks
larryd
I guess the real test would be, is the motor trying to come thru the hood? :thumbs:
#8 jd.rasentrac ONLINE
jd.rasentrac
  • 4,719 Thanks
  • 4,220 posts
Posted April 02, 2013 - 09:36 AM
Photos please, guys, photos please - I don't know what you're talking about (don't understand) - so photos please - let me learn - let this day be a successful day for me - :firejumper:
#9 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 02, 2013 - 06:39 PM
At 2300rpm it's not very rough . I can't do pictures right now .
larryd
#10 JDBrian OFFLINE
  • 9,599 Thanks
Posted April 02, 2013 - 07:33 PM
Heres a link to the thread where I had to deal with the rear mounts on mine. I later had to replace the second rear one which was cracked on the bottom.
http://gardentractor...l= motor mount
