Mf10
48 replies to this topic
#31 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted April 04, 2013 - 06:24 PM
DH1:  Do you have a picture of the right side of the ring starter style tracter you posted earlier??  Reason I ask is my tractor, while not having the long lever on the left side,  mine does have an opening on the deck that would appear to have had one there  at one time.  Also in that picture I  see a black knobed lever in lower middle directly below steering wheel Mine has that, but no indication what it is for.
Early model S/G right side
Late model Ring Gear right side
I think you talking about the hood latch
  • crokit said thank you
#32 crokit OFFLINE
crokit
  • 11 Thanks
  • 30 posts
Posted April 07, 2013 - 08:03 AM
hope I did this right  Here's the tractor
#33 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 07, 2013 - 08:07 AM
picture was there a minute ago, now it's gone????
#34 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 07, 2013 - 08:11 AM
I see you have an attachment there, meaning you DID upload something... But it looks as if it may have been deleted.
This can happen if you use the back button and then resubmit the post.
#35 crokit OFFLINE
crokit
  • 11 Thanks
  • 30 posts
Posted April 07, 2013 - 08:16 AM
Here's my  MF10  Hope I did it correct.tractor 001.jpg tractor 002.jpg tractor 003.jpg tractor 004.jpg tractor 005.jpg tractor 006.jpg tractor 008.jpg tractor 008.jpg tractor 007.jpg
  Still not sure what year.  Best as I can tell model # hh100-1150918
Serial # 88108115  Also has 98-0-6 stamped on r side of motor above pulley post
  • MH81, HowardsMF155 and boyscout862 have said thanks
#36 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted April 07, 2013 - 08:30 AM
Nice looing machine there.
Here you can look up the year.
Looks like the choke cable may be got too close to the exhaust pipe, and
melted the liner.
  • MH81, chances882003 and crokit have said thanks
#37 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 07, 2013 - 08:39 AM
Yep, you're right, the OEM SN tag is missing.
The serial of the engine may be a good clue. I will look into it, I remember someone being able to translate those...
(If you are "someone" please pipe up!)
#38 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 07, 2013 - 08:47 AM
I found several references to decoding the sn... Just not the format you have.
Could you verify that is all the numbers on the tin?
#39 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted April 07, 2013 - 09:05 AM
crokit, looks like you have a very nice machine there.  Thanks for the pictures.
#40 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted April 07, 2013 - 10:15 AM
Your tractor has the round muffler, if that's the type of muffler that it came with then your tractor is a 68 to 71 model.
#41 crokit OFFLINE
crokit
  • 11 Thanks
  • 30 posts
Posted April 08, 2013 - 01:31 PM
  It appears that is it.  It's in a very tough spot to see/read it all.  It's on the engine itself.  Is this # just for the engine??
#42 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 08, 2013 - 08:47 PM
Yep, what we're trying to do is narrow that 4 yr window down some for you.
#43 crokit OFFLINE
crokit
  • 11 Thanks
  • 30 posts
Posted April 21, 2013 - 06:16 AM
Earlier I posted what I believed to be the Model # and Serial # for my MF 10. I believe I now have the correct #s.
  Model # hh100-1150978   S#- 88108116.  These are located on a metal tag riveted to front engine shroud, right behind the fuel line where it exits the shroud and connects to the carb.
  I'm hoping someone can I.D. the year based on these #'s.
  Also, the starter I purchased for this doesn't seem to be a proper fit.  Are both bolts that secure it to the block the same size??  The rubber hood that covers the post on the starter that extends to the fly wheel:  Does this get removed before installation??
   Once again, I thank much for your help!!
Edited by crokit, April 21, 2013 - 06:17 AM.
#44 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 21, 2013 - 06:31 AM
In the model number, could you look one more time at the ending "8"? That might actually be a letter. I see references to hh100-115097 d, c, e but no 8
#45 chiefgoodman OFFLINE
chiefgoodman
  • 36 Thanks
  • 123 posts
Posted April 21, 2013 - 08:46 AM
Welcome and good luck with the machine. My 12H has a 72 stamped on the rear axle. Not sure if that will help.
