Wanted
Clinton 1200
clinton
2 replies to this topic
#1 Columbia236 ONLINE
Columbia236
  • 343 Thanks
  • 117 posts
Posted March 31, 2013 - 05:28 PM
Clinton 1200 engine  and or  Clinton crankshaft part number 12100/46-207   Thanks
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,173 Thanks
  • 5,770 posts
Posted March 31, 2013 - 06:06 PM
Good luck. :D
#3 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted April 01, 2013 - 08:22 AM
12100 is for a Clinton 1200-2000 standard model.  The plain 1200 uses something different and the A-1200 uses something different.
Crankshafts are probably the most "customizable" for each application.  Clinton models had variants for different applications.  The 1200-2000 has about 12 different crankshafts depending only on the rest of the code, the part after the dash, "2xxx" where the "x" stands for a number. The standard 1200 will have a three digit code probably "1xx" or a four digit "1xxx" series.
I have a box of cranks, but no 12100.
If you have the IPL and model variant sheet, you can verify that that's the right part, otherwise post it and I can check my manual.
Ben W.
Also tagged with one or more of these keywords: wanted, clinton
