Large Wheel Weights
11 replies to this topic
#1 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,796 Thanks
  • 5,094 posts
Posted March 30, 2013 - 10:09 PM
Got these today at an auction.   Diameter is fourteen and a half inches so I figure they are for 15 or 16 inch rims.  Thickness is inch and one eighth - weight 40 lbs. each.   Totally flat front and back with odd three bolt mounting holes.  There is "E469" embossed in the casting.
Anyone have a clue what they fit?
Edited by Gtractor, March 30, 2013 - 10:45 PM.
#2 MH81 OFFLINE
  • 29,978 Thanks
Posted March 30, 2013 - 10:48 PM
Looks like 7110 painted on one. Case has a 7110 with 16" fronts but no idea what hole pattern... Wouldn't think 40 would be of much use of big tractor.
What is the c to c on the mounting holes?
  • Gtractor said thank you
#3 Gtractor OFFLINE
Gtractor
  • 9,796 Thanks
  • 5,094 posts
Posted March 30, 2013 - 11:03 PM
Ten and 3/8 inches c to c.  I was thinking with large dia. and only 40 lbs they must be for a two wheeler tractor.  ??
The yellow paint says:  470G
#4 MH81 OFFLINE
  • 29,978 Thanks
Posted March 31, 2013 - 12:50 AM
Those numbers don't produce anything useful either.
Best I can do is :bump: the thread.
#5 WHdbJD ONLINE
WHdbJD
  • 701 Thanks
  • 523 posts
Posted March 31, 2013 - 05:57 AM
Hmmmm....looks like a faded David Bradley red, but they don't look like the db weights I've seen.
#6 Gtractor OFFLINE
Gtractor
  • 9,796 Thanks
  • 5,094 posts
Posted April 02, 2013 - 05:57 AM
bump
#7 KennyP ONLINE
  • 40,899 Thanks
  • 47,099 posts
Posted April 02, 2013 - 06:04 AM
How big is the center hole? What is the spacing on the other 2 holes? I don't know of any wheels with only 3 mounting holes.
#8 Gtractor OFFLINE
Gtractor
  • 9,796 Thanks
  • 5,094 posts
Posted April 02, 2013 - 08:05 PM
center hole is 3 and 3/4 inches and  the two hole mounting holes are 8 inches apart.    They certainly are odd.
#9 KennyP ONLINE
  • 40,899 Thanks
  • 47,099 posts
Posted April 02, 2013 - 08:12 PM
Center hole isn't big enough for going inside a wheel. They are an oddball set, but someone knows what they are for! May take time, but it will come around.
#10 Gtractor OFFLINE
Gtractor
  • 9,796 Thanks
  • 5,094 posts
Posted May 06, 2013 - 08:48 PM
bump
#11 Gtractor OFFLINE
Gtractor
  • 9,796 Thanks
  • 5,094 posts
Posted June 27, 2013 - 05:46 PM
FOUND IT!!!
Took some time today to see if I could find a wheel that matches this bolt pattern. The BlackHawk two wheeler had odd holes in the wheel disk out close to the rim so I set the weights on and TADAH!!!
First pic shows what the wheel looks like just for reference.
I should really get this tractor out and paint it up nice. I had it running several years ago so it'd be done in a weekend. Well two weekends - one to dig it out of the shed and one to clean/paint.
:toilethead:
For those that don't know what a BlackHawk looks like I have a picture of the tractor in the registry.
http://gardentractor...wk-two-wheeler/
#12 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted June 28, 2013 - 12:42 AM
well I didn't even think to look at my Blackhawk. Been sitting on the shelf in the back shop now for a few yrs got a picture of it someplace.................................
