Update To Driveway Grader
9 replies to this topic
#1 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,203 Thanks
  • 950 posts
Posted March 30, 2013 - 08:44 PM
         Built myself a driveway grader and was asked to share. My gravel driveway is 150 to 200ft long, and goes downhill and every time there's a bad rain storm, it erodes gullies in it, big enough to lose a small car in them lol. so I was forced to build a gravel grader.
         Couldn't afford to buy one so I went to the scrap yard & found the steel I needed for the frame and 3 point receiver, and got really fortunate and found a bucket of old safety S hooks. Fortunate cuz safety S hooks are all ready case hardened, and would work great to dig out the old gravel and bring it to the surface.
         So first I straightened out the S hooks (no small feet mind you, vary case hardened lol) two torches and a 5ft cheater pipe and to people to straighten out the hooks. Never came across steel so hard to bend when glowing red hot. Then built the frame work, welded the straightened hooks onto the framework. Then built the 3 point receiver, Then last but not least built a back blade that I could lock in an up position and let it down easily enough not to through my shoulder out.I have a short video but I was unable to upload it. I also forgot to take B4 pic's of driveway gullies, sorry, got to trust me that they were there B4 I graded lol.
      Ok KennyP was able to get some close up pic's today.IMAG0584.jpg Here's a pic of the old safety hooks I used, the reason I believe I found them in the scrap yard is that they are now illegal. IMAG0585.jpg I used a long arm bar to reduce the weight and pull on my shoulder, and it's just about right. IMAG0586.jpg Here it shows the grader in down position. I put a stopper on it so the grader doesn't drop below 2" below the tines,
       IMAG0587.jpg Here it shows the handle and upper handle lock position. I cut the metal at an angle so when I'm pulling the handle up it will slide easily around up and into the upper lock position. Next pic is showing handle in upper position. IMAG0588.jpg
       In this pic I show the side of the grader so you can see that I boxed the grader. I built my first one when I was 14yrs old and I just put a back blade on it, only to find out the gravel flows out of the sides where I didn't want it to go. Having sides the same height as back blade solved the problem, and contained the gravel.IMAG0589.jpg IMAG0590.jpg
        Here I shoe the fulcrum, again making it easier to lift without throwing out my already bad shoulders. IMAG0591.jpg IMAG0592.jpg
        These next Pic's is to just simply brag about my Uncle. Olcowhand. When he restored my MF for me he also personalized it for me. Putting a decal on both sides stating  Ron's Toy  IMAG0593.jpg He also took time to make me a staring wheel center piece that I keep in this velvet bag IMAG0594.jpg I keep it there because it is so nice I'm afraid it will get destroyed if I put it on the steering wheel. IMAG0595.jpg as you can see it's a beautiful piece. IMAG0596.jpg I pit it on the steering wheel just to take a pic of it, then I put it back in the bag. May be if I get to come to a plow day I'll install it for that weekend, but only then, once plow day is done back in the bag it goes lol
Edited by BaumBaum, March 31, 2013 - 07:48 PM.
  • Gtractor, hamman, KennyP and 6 others have said thanks
#2 Grumpy ONLINE
Grumpy
  • 748 Thanks
  • 624 posts
Posted March 30, 2013 - 08:46 PM
Looks good.
  • Craig. said thank you
#3 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Looks real good , both the driveway and grader :thumbs:
#4 boyscout862 OFFLINE
  • 13,693 Thanks
  • 9,476 posts
Posted March 30, 2013 - 09:03 PM
Nice work. Its great when a new tool can save time and work. Even better when you build it yourself. Good Luck, Rick
#5 Michiganmobileman OFFLINE
Posted March 30, 2013 - 09:18 PM
Looking good, grader, driveway and tractor. Nice job!
#6 shorty ONLINE
shorty
  • 5,922 Thanks
  • 5,453 posts
Posted March 30, 2013 - 10:01 PM
That is a neat design. I like how you can easily lift the grader and just use the teeth. Gives me ideas for the back blade I hope to build.
#7 olcowhand ONLINE
  • 43,182 Thanks
  • 32,014 posts
Posted March 30, 2013 - 10:02 PM
I like that!  Don't think you ever sent me pics of that!
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 30, 2013 - 10:03 PM
Nice looking unit it seems to work very well
#9 KennyP ONLINE
  • 41,519 Thanks
  • 47,427 posts
Posted March 31, 2013 - 08:08 AM
That is neat! Now you have me thinking again! :smilewink:  That would be very useful. Thanks for sharing. May ask for more pics (close ups of it). Looks easy to build. Wish I had a bunch of RR spikes!
#10 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,203 Thanks
  • 950 posts
Posted March 31, 2013 - 11:03 AM
I'll try to get some more pic's this afternoon after I take the wife out for Easter.
