Ac Big Ten, Intermitent Spark
ac big ten b&s 243xxx intermitent
5 replies to this topic
#1 boyscout862 ONLINE
  • 12,573 Thanks
  • 9,050 posts
Posted March 30, 2013 - 05:46 PM
I finally have my Big Ten back together(pretty much). It started for a few seconds and then died. The carb float valve leaks a very little bit. The spark seems good when turned by hand and when the S/G first turns it. Then as it utrns more the spark gets weaker and then stops. I repolished the points and changed the plug but it gets weaker the more it turns until it rests a little. I suspect the magneto but that is a real pain to get at. Any thoughts?  I hope that ACHomesteader is out there because he knows this stuff. Thanks, Rick
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted March 30, 2013 - 05:55 PM
Rick it sounds to me that the condenser is toast.
  • IamSherwood and boyscout862 have said thanks
#3 MH81 OFFLINE
Posted March 30, 2013 - 06:35 PM
I would almost bet you a peanut butter cookie that Chris nailed it.
That or bad ground to the mag
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted March 30, 2013 - 09:43 PM
:iagree: :iagree: :iagree:
#5 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted March 31, 2013 - 06:33 AM
Same here.
#6 boyscout862 ONLINE
  • 12,573 Thanks
  • 9,050 posts
Posted March 31, 2013 - 07:14 AM
Thanks guys, I'll replace it this afternoon. Rick
Also tagged with one or more of these keywords: ac big ten, b&s 243xxx, intermitent
