Case 648 Hydraulics - diagnostics
3 replies to this topic
#1 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted October 09, 2010 - 01:06 PM
Well thanks to hydriv for the instructions
Drop the 1/4" hex plug. Remove the line, orange one in the picture, that crosses the path over the hex plug with 5/8" wrench. Screw the extension line in there. Put line with 5/8 back on. Screw gauge onto extension line. I got the gauge from Northern, zip tied on there
In HIGH range, against a rock, it will put 2500psi. The relief valve goes off. wont spin the tires
In LOW range, against a rock, it will put 2500psi. The relief valve goes off. wont spin the tires
And I drove it down the block a couple times to heat up the oil. The pressure stays the same sadly. The drive force does not. Well, Even when cold it wont spin the tires even with these low tires so its not like its a monster when its first started.
Also, I think I said I didnt hear the relief valve. Well I spoke to soon before. Of course it would be nice to not hear it. I think then itd be a $200 problem instead of an $800 one......ouch
Thanks
#2 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted October 09, 2010 - 02:13 PM
spoke too soon. talked to Brian Hildreth and he talked me through the linkage.
Apparently a little bit of play make alot of difference. And too me alot of play is 1/2" but 1/16"/1/8" makes a big difference.
hydriv told me that.
GUESS I SHOULD DO WHAT IM TOLD LOL
thanks all! the community for these tractors is great
THANKS ALL
#3 caseguy OFFLINE
  • 1,629 Thanks
Posted October 09, 2010 - 02:47 PM
I was looking at your pics and I think you need to ease up on the caffeine a little LOL! But seriously, I'm glad you got it fixed.
#4 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted November 05, 2010 - 04:38 PM
Mike, it is nice seeing your Case 648 at this stage and then seeing the video of it working :thumbs:
